Hi everyone,
I have Mi Robot Vacuum Mop 2 Pro + integrated to HA via HACS custom component → Xiaomi Miot Auto. Default HA integration does not support this model… At first I’ve been using integration by Concentricc and it causes same issue like the Miot integration.
Issue:
I have automation script that turns off docking station (socket switch)… If vacuum is in idle state ( plus not charging) it will turn off after some time. In this case you cant control the vacuum via Mi Home app too.
Requirement:
I want to somehow wake up the vacuum from tie off state not manually (pressing button on vacuum). Calling service vacuum.turn_on via developer tools do nothing…
