I don’t understand what you mean, what is not possible with HA? To have a map like this? Or to have zoned cleaning? Because if it is the latter, this works perfectly fine with HA. I have presets to clean my rooms but I also have this interactive map card.
Edit: about the scrolling @3_14 could you make it that it won’t scroll horizontally as well? I use swipe-card and that works nicely, until I want to draw zones. It is a bit harder within a swipe card as it will try to swipe left/right.
Otherwise this card is really great. Here is an example of what I made.
If you check the post what I shared you see what I mean. Have you tried the multiple zoned cleaning with HA automation? Not only one room but 3-4 rooms one after another, without any interuption or without that the vacuum goes back to the dock after every finished zone.
Well I have a Node RED flow to manage it but I’d like to know the HA solution too.
I have a map like your and it is working fine but not able to manage the scheduled multiple room cleaning, (I guess maybe in the future ).
Ah I understand now. But my bedroom consists of 3 zones and that works without a problem as far as I know. It is a single button yes, but it has 3 zones.
Honestly I haven’t really tried otherwise but to my knowledge the robot gets lost if you set up more than 5 zones at once. I have read that somewhere (can’t remember where though).
Could it be you are trying to clean more than 5 zones at once?
I will play around with this some more as I don’t use Node red and only use HA automations.
i am struggling with the map.png, what resolution does it needs to be?
i have an orginal floor plan from the architect, if i take a screenshot/png from it, the zones are just to big, seems it needs to be smaller resolution
how do you guys make the plan with a non-rooted device ?
still struggling, with map, i have now idea how to set this up, my code is below, the zones there in the code, those coordinates are actually correct, i use them already now in my automations
but on the map itself, its so huge, seems to be resolution …
i think the red map, is like 1 zone for my kitchen or hallway, but its not that huge like its now in screenshot
the blue lines in pen, those are actual the zones, so the red zone should be like that
how can i adjust this?
for me also not clear what is the base and reference point?
Base position - coordinates of a point (on a image) that maps to position [25500,25500] in vacuum coordinates. It is usually equal or very near to localization of base station.
Reference point - coordinates of a point (on a image) that maps to position [26500,26500] in vacuum coordinates. I should be about 1.5m from base station.
If you use screenshot approach you can first call service:
and then make a screenshot. In this case corners of a rectangle shown in Mi Home will mark desired points on a map: base position - near docking station, reference point - on a diagonal from base position.
aha, more clear now, ok, gonna install those tools
if my screenshot above is like for example 1000 / 700
then base is around x : 800 , y 600 , ref = = like x 850 , y 650
so starting point x , y , is from left corner below, right?
hi @3_14. i really like your project and installed it. Did make a pixel calc for base and reference, seems to be ok. map is loaded and can view the zones. Some strange thing here:
Whatever action i try, go to target or zone cleanup, nothing happens when pressing start. But via the developer tool choosing vacuum_send_command is just working fine. Following logging appears when pressing start:
2019-08-11 21:34:16 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.139766057424880] None @ data['zone'][0]
File "/usr/src/app/homeassistant/components/websocket_api/commands.py", line 121, in handle_call_service
connection.context(msg))
File "/usr/src/app/homeassistant/core.py", line 1130, in async_call
processed_data = handler.schema(service_data)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 267, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 589, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 427, in validate_mapping
raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: None @ data['zone'][0]
