@3_14 you are absolutly right, this was my mistake, by misconfiguring the base and reference point.
so my first thought was, that the linting wasnāt right.
i got it right now, so thanks for making such nice integration.
In yaml this is not possible, because the component does not include the zone template.
However it is possible with .js (example: your card) or python script
Need an advise. I installed this card and it worked well.
After a while I tried to translate titles to Russian and it didnāt work.
Script works with English titles even after I translated all text in texts.js.
It looks like I need to clean some js cash or something. But I donāt know where to search for it.
Could you help, please?
Can anyone offer advice on how to define the preconfigured zones? Is it [x1, y1, x2, y2], where point 1 is the top left corner of a zone and point 2 is the bottom right? And are the numbers still corresponding to the pixels in the image, or something else?
I have never been able to connect flovac to my botā¦ tried most of every method starting with bluestacks, then android phone. I do however think this may be a network issue, but unfortunately I donāt know too much, just that they all on the same ip and subnet range. I run unifi and a number of apās. It could also do with possibly the location of the server you select on the mihome app as well as flovac. For me, i select Jersey for server option in mihome, but in flovac, there is only eu. Again, i dont know if this is it. Just that i canāt connect, but all that I can think of is what I have mentioned aboveā¦
It seems you have figure out the secret:).
like about 1.5m between 25500 and 26500. Is possible to generate live map by ourself? just curious about the theory.
Againļ¼Appreciate it.
This can be done with Valetudo and other methods, but it does, as 3_14 states, require a rooted vacuum.
One of the more interesting methods is this one, since it doesnāt require anything else than SSH on your vacuum. Iād love to have that in some combination with this card.
