Piggyback
(René)
December 15, 2021, 8:28pm
960
Thank you very much Piotr! this is exactly it! I had read the posts and thought that referred to this card, but not the integration. Went back to the map extractor documentation and I think I didn´t have it as it was added after I installed it and didn´t read the changes when updating.
Appreciate the help!!
henrikrox
(Henrikrox)
December 16, 2021, 7:15pm
961
Perhaps stupid now, but am i supposed to use card-mod for this or do i need to change somethign somewhere else.
For this one: --map-card-secondary-color
3_14
(Piotr Machowski)
December 16, 2021, 9:34pm
962
You can add it to your theme in yaml file
cpoulsen2
(Cpoulsen2)
December 18, 2021, 10:27am
963
This looks really great! Been using V1 for a long time in lovelace. Got V2 working in lovelace too.
I’m struggeling to add V2 within the YAML file. I would like to add the manual path feature.
Any chance you can who how it is connected from the YAML file to lovelace? Will I just add your demo code to the config yaml file?
Emphyrio
(Roelof)
December 18, 2021, 4:07pm
964
I’m having some troubles with my map. It used to display properly, at some time didn’t anymore. I removed and reinstalled through HACS. But the first zone I drew is now stuck like some kind of wart on the map… can’t get rid of it, uninstalling/reinstalling doesn’t fix it, cleaning cache doesn’t either… I’m lost.
Can you help out?
Edit: Ah… it seems the card remembers the last zone I drew and keeps that as a blue box. Still, I would love to get rid of it. Is that possible?
3_14
(Piotr Machowski)
December 19, 2021, 12:40am
965
You have to install this script and use vacuum_follow_path
template in map_modes
3_14
(Piotr Machowski)
December 19, 2021, 12:45am
966
It’s not card, but the camera. You have to change
draw: ["all"]
to:
draw:
- charger
- cleaned_area
- goto_path
- ignored_obstacles
- ignored_obstacles_with_photo
- no_go_zones
- no_mopping_zones
- obstacles
- obstacles_with_photo
- path
- predicted_path
- room_names
- vacuum_position
- virtual_walls
fiftys
December 19, 2021, 9:10am
967
I dont want to come off sounding inconsiderate. I very much appreciate the integration update. But the instructions for this arent very clear to be honest.
I still cant get any of it to work.
type: custom:xiaomi-vacuum-map-card
entity: vacuum.rosie
map_source:
camera: camera.vacuum_map
calibration_source:
camera: true
map_modes:
- template: vacuum_clean_zone
- template: vacuum_goto
- template: vacuum_clean_zone_predefined
- template: vacuum_follow_path
predefined_selections:
- zones:
- - 24245
- 25190
- 27495
- 27940
- - 27492
- 26789
- 28942
- 27889
- zones:
- - 25317
- 29250
- 26755
- 30757
- zones:
- - 25180
- 25142
- 30384
- 29182
- zones:
- - 30441
- 25737
- 33775
- 28064
- zones:
- - 31510
- 30455
- 37109
- 33977
- zones:
- - 32202
- 28693
- 36983
- 30329
- zones:
- - 33775
- 25045
- 37109
- 28819
- zones:
- - 37046
- 25611
- 40569
- 28819
- zones:
- - 36920
- 22277
- 40632
- 25611
- zones:
- - 40128
- 24793
- 44972
- 26429
- zones:
- - 43588
- 26240
- 44972
- 27498
- zones:
- - 44532
- 25359
- 51137
- 26366
- zones:
- - 46734
- 22151
- 51200
- 25485
- zones:
- - 44029
- 22214
- 47614
- 23786
- zones:
- - 44972
- 23724
- 47111
- 25296
- zones:
- - 42771
- 23849
- 45035
- 24793
- zones:
- - 41324
- 22654
- 42771
- 24856
- zones:
- - 30108
- 29005
- 32319
- 30798
- name: Path
icon: mdi:map-marker-path
selection_type: MANUAL_PATH
max_selections: 5
repeats_type: NONE
max_repeats: 5
service_call_schema:
service: script.vacuum_follow_path
service_data:
path: '[[selection]]'
repeats: '[[repeats]]'
predefined: 'false'
entity_id: '[[entity_id]]'
- name: Manual Point
icon: mdi:map-marker-plus
selection_type: MANUAL_POINT
max_selections: 5
repeats_type: NONE
max_repeats: 5
service: vacuum.do_point
service_data:
point: '[[selection]]'
point_x: '[[point_x]]'
point_y: '[[point_y]]'
predefined: 'false'
style: |
ha-card {
border: solid 6px var(--accent-color);
border-radius: 0px;
background: rgba(0,0,0,.8);
box-shadow: none;
keep:
margin: true
box_shadow: true
background: false
outer_padding: true
border_radius: true
vacuum_platform: default
gives me this error:
Mode MANUAL_PATH does not support predefined selections
and adding the script into my scripts.yaml. leads to a bunch of errors as well:
any help would be appreciated
edit: okay I figured out where to add the template instead of the mapmode at the top, I put it under
- name: Path
now im getting errors from the script:
3_14
(Piotr Machowski)
December 19, 2021, 9:18pm
968
Here you have a fixed config:
map_source:
calibration_source:
camera: true
map_modes:
- zones:
- - 24245
- 25190
- 27495
- 27940
- - 27492
- 26789
- 28942
- 27889
- zones:
- - 25317
- 29250
- 26755
- 30757
- zones:
- - 25180
- 25142
- 30384
- 29182
- zones:
- - 30441
- 25737
- 33775
- 28064
- zones:
- - 31510
- 30455
- 37109
- 33977
- zones:
- - 32202
- 28693
- 36983
- 30329
- zones:
- - 33775
- 25045
- 37109
- 28819
- zones:
- - 37046
- 25611
- 40569
- 28819
- zones:
- - 36920
- 22277
- 40632
- 25611
- zones:
- - 40128
- 24793
- 44972
- 26429
- zones:
- - 43588
- 26240
- 44972
- 27498
- zones:
- - 44532
- 25359
- 51137
- 26366
- zones:
- - 46734
- 22151
- 51200
- 25485
- zones:
- - 44029
- 22214
- 47614
- 23786
- zones:
- - 44972
- 23724
- 47111
- 25296
- zones:
- - 42771
- 23849
- 45035
- 24793
- zones:
- - 41324
- 22654
- 42771
- 24856
- zones:
- - 30108
- 29005
- 32319
- 30798
style: |
ha-card {
border-radius: 0px;
box-shadow: none;
keep:
margin: true
box_shadow: true
background: false
outer_padding: true
border_radius: true
Here you have a source of problems with script:
You shouldn’t provide entity id of your vacuum in it. Just remove it and everything should be ok
fiftys
December 21, 2021, 11:01am
969
much appreciated, works now.
Also think ive got the rest figured out as well. Such an amazing job, for an amazing custom integration. Massive amount of options, almost overwhelming to be honest. So much that its hard to put in perspective what can be done.
I think it just needs a few more examples under each block of options. That would be a tremendous help.
Thanks, truly a great thing here.,
3_14
(Piotr Machowski)
December 21, 2021, 11:29am
970
Yeah, there are a lot of options and documentation is not perfect (I really hate writing docs ), but I will try to improve it
Hello, I’m having an issue with the “Rooms” function. I pulled my room segment numbers. I have segment IDs 16,17,18,19. I used the vacuum_follow_path function to create the outline. However, when I select the room I want cleaned from the dropdown. The vacuum undocks itself then immediately redocks. Do I have to use a room number from Xiaomi or can I create a new one? Help?
entity: vacuum.edna
map_source:
camera: camera.xiaomi_cloud_map_extractor
crop:
top: 180
bottom: 180
left: 100
right: 100
calibration_source:
camera: true
map_modes:
- icon:
x: 23537
'y': 28724
zones:
- - 19615
- 25056
- 28298
- 31647
- icon:
x: 24830
'y': 33169
zones:
- - 20574
- 31661
- 29097
- 35429
- icon:
x: 25548
'y': 37013
zones:
- - 23558
- 35388
- 28353
- 38624
- template: vacuum_clean_segment
- room: Downstairs
outline:
- - 24963
- 25088
- - 22217
- 25123
- - 22182
- 26096
- - 24998
- 26026
- - 25032
- 26165
- - 24754
- 26235
- - 24754
- 26895
- - 25171
- 26930
- - 25206
- 30823
- - 22495
- 30857
- - 22530
- 29189
- - 21174
- 29120
- - 19645
- 29293
- - 19680
- 31691
- - 21035
- 31622
- - 21105
- 32838
- - 21870
- 32908
- - 21765
- 34680
- - 25171
- 34750
- - 25137
- 35480
- - 23573
- 35515
- - 23538
- 38573
- - 26979
- 38538
- - 26909
- 36627
- - 28299
- 36592
- - 28230
- 35376
- - 29134
- 35341
- - 29168
- 31796
- - 26596
- 31726
- - 26596
- 26061
- - 28195
- 26061
- - 28230
- 25123
map_locked: true
3_14
(Piotr Machowski)
December 28, 2021, 3:45am
972
Your config looks ok. You have to use room numbers retrieved from the vacuum. What vacuum model do you have?
AndreasEge
(Andreas Ege)
December 28, 2021, 8:24am
973
Great card.
How can I remove the 3 incircled icons?
3_14
(Piotr Machowski)
December 28, 2021, 1:54pm
974
Remove append_icons
from config
Borge76
(Børge Lundhaug)
December 28, 2021, 7:37pm
976
Andreas, I guess you have buttons for the different floor maps? Can you share your icon config?
AndreasEge
(Andreas Ege)
December 29, 2021, 12:41am
977
Here you go
icons:
- icon: mdi:numeric-0-box
tooltip: Kælder
tap_action:
action: call-service
service: vacuum.send_command
service_data:
entity_id: vacuum.roberta
command: load_multi_map
params: 3
- icon: mdi:home-floor-0
tooltip: Stueetagen
tap_action:
service_data:
params: 0
- icon: mdi:home-floor-1
tooltip: 1. sal
tap_action:
service_data:
params: 1
- icon: mdi:home-floor-2
tooltip: 2. sal
tap_action:
service_data:
params: 2
3_14
(Piotr Machowski)
December 29, 2021, 2:27am
978
I will try to incorporate this feature in present chooser
Borge76
(Børge Lundhaug)
December 29, 2021, 11:13am
979
Thanks a lott, this helps a newbie
