And when i using this with a fixed map picture ?
You will have to recalibrate the map every time the map changesā¦
I would make a fixed map on which to mark the rooms. Then I would just start zona cleaning so the map would not change.
Or can I create and name zones with Cloud-Map-Extractor?
Ok, this is doable
You can use map extractor to help you calibrate your map image instead of FloleVac (guide for FloleVac, getting coordinates from Map Card).
Ohh thatās it, thank you!
And thank you for your work, great card!
thanks, I made this. NOw when I select zone to clean it made green (i set this color).
But it is posible that when I chose zone to clean and start clean this color will disapear? Now after start clean zone is still green and I donāt see how the vaccum clean this zone. The color disapear when he finish cleaning but when cleaning in progress I donāt see what vaccum doing
Soooo you want to clear selection in card when cleaning is started?
Something like that. The best way will be if color what I mark zone to cleane will be darker but transparent (like green, because in default theme is white and not on my all devices I see what I select).
But I donāt know have make a transparent color. If that is imposible I think that better will be like now - that I select zone to clean and it is colored but when I press start to clean this color desapear and I will be know how vacuum is cleaning.
I tried this:
I selected an area in āzone cleanupā
and push the play button
But pushing the play button is not showing coordinates??
What am I doing wrong?
Or do I need to set something in the configuration?
You need to press and hold the Play button for ~1s, details should be presented in a popup and browserās console.
If it still doesnāt work then you can add debug: true
in cardās config
Thanks for the answer.
I added debug: true, now it is showing up
I added zones to the map very nice feature.
Is it possible to start the zone cleanup menu with the zonelist instead of zone cleanup option?
I switched the template orde in the card, but then no map is showing up
Switching order should be enough, maybe you have a typo in your config
I tried again. Still no map after swopping:
cards:
- type: custom:xiaomi-vacuum-map-card
entity: vacuum.xiaomi_vacuum_cleaner
# debug: true
map_source:
camera: camera.roborock_s5_max_camera
calibration_source:
camera: true
map_modes:
- template: vacuum_clean_zone_predefined
- template: vacuum_goto
predefined_selections:
- icon:
x: 23776
'y': 33690
zones:
- - 22562
- 31763
- 25215
- 35483
- icon:
x: 27913
'y': 27118
zones:
- - 26400
- 24967
- 30249
- 28971
- icon:
x: 26405
'y': 34108
zones:
- - 25205
- 32883
- 28561
- 35393
- icon:
x: 24269
'y': 29015
zones:
- - 22547
- 24908
- 26365
- 32242
Ahh I understand!
I need to copy the zones also with te templates
EDIT:
Yes it is working now
Great, Thats it. Thanks Piotrek
I am still very new to HA but learning more and more everyday. I managed to add our roborock vacuum to HA with both the simple vacuum card and the map card and they were both working fine 2 days ago but today when I checked it says āunavailableā on the simple card and "Missing property:map_source " on the map card. Any tips on what can be wrong or do I need to just redo everything?
Check if all entities exist
Hi!
I have Viomi S9 robot with Xiaomi MioT integration and i would like to manage custom buttons in your card. When Iām putting eg.
label: xxx
Icon: xxx
I have fault.
Do do you have any example how to edit/manage button options? Was trying all night and nothing working for meā¦
