Vacuum Interactive Map Card
This integration is not supported out of the box, you have to configure it manually using services that it and your vacuum support.
Is is possible to show your rooms in the lovelace? Currently Iā€™m just doing thisā€¦
type: custom:xiaomi-vacuum-map-card
map_source:
camera: camera.xiaomi_cloud_map_extractor
calibration_source:
camera: true
entity: vacuum.raife_robot
vacuum_platform: default
Sure:
Hi
having some trouble with the input select dropdown , the dropdown is not collapsed. anyone now why this sudenly happened
Is there a way / a guide / some instructions that I can use to try and create and use a background image rather than the real time map? Iā€™ve the map in place but Iā€™m getting ā€œinvalid configuration, please check your configurationā€ā€¦
Any help / suggestions appreciated !
How and where have you set it up?
Installed via HACS for homeassistant. Latest versions are installed.
It works perfectly when using the realtime map, just getting the error when using a static image.
Can you show your config that results in this error?
This is the code Iā€™m using (created using the Template Editor) which works perfectly - thank you!
I change the map_source to a static image path, and then i get the ā€œinvalid configurationā€ error mentioned above.
entity: vacuum.rosie
map_source:
calibration_source:
  camera: true
map_modes:
  - template: vacuum_goto
  - template: vacuum_clean_zone
  - template: vacuum_clean_segment
    predefined_selections:
      - id: 25
        outline:
          - - 29650
            - 17450
          - - 29650
            - 21100
          - - 32700
            - 21100
          - - 32700
            - 17450
        label:
          text: Room
          x: 31175
          y: 19275
          offset_y: 35
        icon:
          x: 31175
          y: 19275
      - id: 27
        outline:
          - - 29750
            - 17500
          - - 29750
            - 19350
          - - 30450
            - 19350
          - - 30450
            - 17500
        label:
          text: Room
          x: 30100
          y: 18425
          offset_y: 35
        icon:
          x: 30100
          y: 18425
      - id: 26
        outline:
          - - 24850
            - 17550
          - - 24850
            - 21200
          - - 28800
            - 21200
          - - 28800
            - 17550
        label:
          text: Room
          x: 26825
          y: 19375
          offset_y: 35
        icon:
          x: 26825
          y: 19375
      - id: 28
        outline:
          - - 28450
            - 20300
          - - 28450
            - 25250
          - - 32050
            - 25250
          - - 32050
            - 20300
        label:
          text: Room
          x: 30250
          y: 22775
          offset_y: 35
        icon:
          x: 30250
          y: 22775
      - id: 16
        outline:
          - - 24900
            - 21100
          - - 24900
            - 22550
          - - 26350
            - 22550
          - - 26350
            - 21100
        label:
          text: Room
          x: 25625
          y: 21825
          offset_y: 35
        icon:
          x: 25625
          y: 21825
      - id: 24
        outline:
          - - 29650
            - 22000
          - - 29650
            - 25500
          - - 32800
            - 25500
          - - 32800
            - 22000
        label:
          text: Room
          x: 31225
          y: 23750
          offset_y: 35
        icon:
          x: 31225
          y: 23750
      - id: 17
        outline:
          - - 24900
            - 22750
          - - 24900
            - 24950
          - - 28550
            - 24950
          - - 28550
            - 22750
        label:
          text: Room
          x: 26725
          y: 23850
          offset_y: 35
        icon:
          x: 26725
          y: 23850
      - id: 23
        outline:
          - - 24900
            - 24900
          - - 24900
            - 27600
          - - 28650
            - 27600
          - - 28650
            - 24900
        label:
          text: Room
          x: 26775
          y: 26250
          offset_y: 35
        icon:
          x: 26775
          y: 26250
      - id: 22
        outline:
          - - 29850
            - 25150
          - - 29850
            - 28750
          - - 32800
            - 28750
          - - 32800
            - 25150
        label:
          text: Room
          x: 31325
          y: 26950
          offset_y: 35
        icon:
          x: 31325
          y: 26950
      - id: 21
        outline:
          - - 24950
            - 25250
          - - 24950
            - 35850
          - - 33450
            - 35850
          - - 33450
            - 25250
        label:
          text: Room
          x: 29200
          y: 30550
          offset_y: 35
        icon:
          x: 29200
          y: 30550
      - id: 20
        outline:
          - - 29650
            - 30800
          - - 29650
            - 35600
          - - 34850
            - 35600
          - - 34850
            - 30800
        label:
          text: Room
          x: 32250
          y: 33200
          offset_y: 35
        icon:
          x: 32250
          y: 33200
      - id: 19
        outline:
          - - 25050
            - 35800
          - - 25050
            - 39550
          - - 27600
            - 39550
          - - 27600
            - 35800
        label:
          text: Room
          x: 26325
          y: 37675
          offset_y: 35
        icon:
          x: 26325
          y: 37675
      - id: 18
        outline:
          - - 25300
            - 39600
          - - 25300
            - 41400
          - - 27150
            - 41400
          - - 27150
            - 39600
        label:
          text: Room
          x: 26225
          y: 40500
          offset_y: 35
        icon:
          x: 26225
          y: 40500
Ok, can you show config that results in this error?
In configuration.yaml I have the following:
camera:
# https://github.com/PiotrMachowski/Home-Assistant-custom-components-Xiaomi-Cloud-Map-Extractor#colors-configuration
  - platform: xiaomi_cloud_map_extractor
    host: 192.168.xx.xx
    token: token_here
    username: username_here
    password: password_here
    draw: ['all']
    attributes:
      - calibration_points
      - rooms
    map_transformation:
      trim:
        top: 10
        bottom: 10
        left: 25
        right: 20
The transformation section Iā€™ve been ā€œplaying around withā€ to see if that made any difference. I have also tried with that section commented out, but with the same result
I have lydsto R1 whatever i do i get this error message on the card, ā€œFailed to retrieve map from vacumā€
Iā€™m at a loss as to how to achive thisā€¦from what I understand I need to be able to convert the realtime map coordinates into another set of numbers that relate to the static image. Iā€™ve looked through this thread, and read through the github pages - FAQs etc.
Either it is not there, or Iā€™m not intelligent enough to figure it out. Iā€™m happy to read through material, so if anyone could supply a link an article; a piece of a thread, I would really appreciate it!
thanks in advance
You can check out this guide, it uses FloleVac, but you can use Map Extractor instead
thanks Piotr, Iā€™ve seen this guide (and had started using it) but when applied to the static image the vacuum was off on the location. Iā€™ve also noticied that any of the examples Iā€™ve seen always use the realtime map - Just to be sure Iā€™m explaining myself properly what I want to achive is the below - please appreciate this is just a mock up, just trying to illustrate my ask.
If what Iā€™m asking is achievable, then Iā€™ll persever with the guide!
thanks in advance
The easiest way to achieve it should be:
  1. Use following config
    debug: true
    map_source:
    calibration_source:
      camera: true
    map_modes:
      - template: vacuum_follow_path
  2. Draw a 3-point path using ā€œFollow pathā€ mode (red points), click start and save all points
  3. Use following config
    debug: true
    map_source:
      image: /local/path/to/image.png
    calibration_source:
      identity: true
    map_modes:
  4. Draw a 3-point path using ā€œFollow pathā€ mode (yellowpoints), click start and save all points
  5. Create calibration using matching pairs of points
UI issues are fixed in v2.0.11
Thank you for your efforts! :beers:
