You can check out this issue:
Is this specifically for Valetudo RE or also the original Valetudo?
And doesnât that also rely on valetudo-mapper (which is a fork of ICantBelieveItsNotValetudo)?
I havenât tried it with original Valetudo, so you have to check it out by yourself. Yes, it relies on valetudo-mapper, my suggestion was to check out controls section
Ah allright, thanks
Hey guys! I am having a problem with this card. I am using a Xiaomi Roborock S5 Max vacuum with xiaomi-miot-auto integration on home assistant 2022.3.5 running on a raspberry pi 4 4/32gb. I generated my config using the generator on the github page. The problem is that the card is basically useless because the buttons are unresponsive. Only the map controls work. Here is the cardâs config: type: custom:xiaomi-vacuum-map-cardentity: vacuum.roborock_s5_max_a_szolga_rob - Pastebin.com I really like the look of the card and want to use it and definitely will buy you some coffee when this error is resolved. Thank you for your time!
Welcome to the forum, Elod
entity: vacuum.roborock_s5_max_a_szolga_robot_cleaner
map_source:
camera: camera.xiaomi_cloud_map_extractor
calibration_source:
camera: true
map_modes:
- template: vacuum_goto
- template: vacuum_clean_zone
- template: vacuum_clean_segment
predefined_selections:
- id: 20
label:
text: ElĆszoba
x: 24925
'y': 22825
offset_y: 35
icon:
x: 24925
'y': 22825
- id: 24
label:
text: Imola
x: 21825
'y': 22025
offset_y: 35
icon:
x: 21825
'y': 22025
- id: 18
label:
text: ElĆd
x: 28350
'y': 21350
offset_y: 35
icon:
x: 28350
'y': 21350
- id: 21
label:
text: Konyha
x: 28325
'y': 24500
offset_y: 35
icon:
x: 28325
'y': 24500
- id: 25
label:
text: Nappali
x: 28525
'y': 26575
offset_y: 35
icon:
x: 28525
'y': 26575
- id: 16
label:
text: Anya Ă©s Apa
x: 21675
'y': 26950
offset_y: 35
icon:
x: 21675
'y': 26950
- id: 17
label:
text: FĂŒrdĆszoba
x: 24975
'y': 27300
offset_y: 35
icon:
x: 24975
'y': 27300
- id: 19
label:
text: Kamra
x: 28000
'y': 28550
offset_y: 35
icon:
x: 28000
'y': 28550
- id: 22
label:
text: Budi
x: 30475
'y': 28775
offset_y: 35
icon:
x: 30475
'y': 28775
If using idâs where did you put the Outline data to?
Compare your config closely with the demo config. Note in particular lines 33 to 67.
@Elod044, the problem is that xiaomi-miot-auto integration is not supported out of the box, because it uses different service calls for different models.
To make it work you have 2 solutions:
- Switch to built-in miio integration (it supports your model)
- Configure card manually to make it work with xiaomi-miot-auto (guide: issue #251)
@Tamsy template vacuum_clean_segment
uses outlines just for rendering, cleaning is done by id, so itâs perfectly fine to skip outline
in config
Thank you for the fast reply! It worked like a charm with the built in xiaomi miio!
This is a great card and thank you for the excellent work done on it, however I need assistance if anybody can please assist. I search this entire forum and did not see the same issue. Basically it does not work for me as any selection I make, I get âFailed to call service vacuum_clean_segment. Service not found.â the same goes for âvacuum_gotoâ and vacuum_clean_zone", however, the middle buttons, start, stop, pause, return to charge, locate all work well.
I have the STYTJ02YM and using the vacuum_platform: KrzysztofHajdamowicz/miio2.
Let me know if you like me to send my config.
Also, does anyone know how to reset the âside brush leftâ and the âfilter leftâ as mine have reached 0h and have changed them but need t reset.
Hi. Please tell me, does it work as a mijia 1c vacuum cleaner? The vacuum_clean_zone function does not work for me. Ref to a demonstration of the problem.
https://youtu.be/P3w-bk5xIvA
Do you use map extractor from dev branch?
Ok, mija 1c is a dreame. dreame_support
is not finished yet, so do not expect it to fully work
Thank you for the quick response. I am using the Xiaomi Viomi Vacuum integration, and so far seems to be the best.
I tried the GitHub - nqkdev/home-assistant-vacuum-styj02ym and the Xiaomi Miio - Home Assistant and both I get the same errors in the log.
Thank you for the link on resetting sensors.
I also tried the reset script as per the link you sent, also does not work. Th log error is: âUnable to send command to the vacuum: No response from the deviceâ
Could you provide a link, the name doesnât say much just by itself
This is the only integration that gives me all the sensors (brush, filter, etc.), all be it as attributes.
Iâve been struggling for 2 weeks now, canât seem to be able to make the card to workâŠ
