Im using the official one, atleast i think so. It says its provided by a custom integration. But im using this one.
So you have to download the latest beta version of the card and use Roborock platform.
I have the latest beta version of the card. But not quite sure what you mean by using the Roborock platform?
In the visual card editor open âvacuum platformâ dropdown and select âhumbertogontijo/homeassistant-roborockâ
So you donât have the latest beta version or you have some caching problem. Try reinstalling the card and cleaning the cache
Thanks for replying!
Im currently using GitHub - humbertogontijo/homeassistant-roborock: Roborock integration for Home Assistant. This integration uses your devices from the Roborock App together with the Roborock app. I found out that when using the code below it actually returns data (so I am probably just unaware where to find a list of possible Tiles):
- tile_id: fan_speed
entity: vacuum.roborock_s7_maxv
label: Fan speed
attribute: fan_speed
icon: mdi:fan
Install the latest beta version and change vacuum platform to Roborock. Tiles will be generated automatically
Thanks! This worked. Is there any way to remove some tiles like âcleaned areaâ for example?
Also, my current config looks like this:
- type: custom:xiaomi-vacuum-map-card
map_source:
camera: camera.roborock_s7_maxv_map
calibration_source:
camera: true
camera_calibration: true
icons: []
tiles: null
vacuum_platform: humbertogontijo/homeassistant-roborock
map_modes:
- template: vacuum_clean_segment
predefined_selections:
- id: 18
icon:
x: 28567
'y': 24258
- id: 20
icon:
x: 27250
'y': 27000
- id: 16
icon:
x: 22900
'y': 24000
- id: 17
icon:
x: 22700
'y': 26800
Is there any way I can âzoom-inâ on the map and lock it? I have a tablet in my living room and the new roborock integration gives me a sort of zoomed-out view.
Many thanks for your replies! Very much appreciated
Yes, you can use following config (basically create a condition that will always be false):
append_tiles: true
tiles:
- tile_id: cleaned_area
conditions:
- entity: sun.sun
state: disabled
Yes, but this feature doesnât work perfectly (documentation):
map_source:
crop:
left: 10
right: 20
top: 30
bottom: 40
Hi All,
I was playing around with some things and created a nice pull down (input_select) to let vacuum clean rooms (segments) and per room (segment) I add specific settings what to do. Maybe itâs already add here somewhere in the 1531 posts. But here is mine.
I added the input_select into Homekit also so now can ask Siri: Clean kitchen or Clean livingroom, etcâŚ
input_select:
helpers_roborock:
icon: mdi:nintendo-switch
options:
- "off"
- "Clean full"
- "Clean kitchen"
- "Clean bedroom"
- "Clean diningroom"
- "Clean hallway"
- "Clean livingroom"
initial: "off"
Automation behind it:
# VACUUM Settings per room
- id: "a20ae3e8-53c5-45b4-accf-0f3dec586552"
alias: "Cleaning - Clean actions"
mode: restart
- platform: state
entity_id: input_select.helpers_roborock
condition: []
- choose:
# Return to base
- conditions:
- condition: state
state: "off"
sequence:
- service: vacuum.return_to_base
entity_id: vacuum.roborock_s8
# Clean full
- conditions:
- condition: state
state: "Clean full"
sequence:
- service: select.select_option
entity_id: select.roborock_s8_mop_intensity
option: intense
entity_id: select.roborock_s8_mop_mode
option: deep
- service: vacuum.set_fan_speed
fan_speed: max
- service: vacuum.start
# Clean kitchen
- conditions:
- condition: state
state: "Clean kitchen"
sequence:
option: intense
option: deep
fan_speed: max
- service: roborock.vacuum_clean_segment
segments: 16
# Clean hallway
- conditions:
- condition: state
state: "Clean hallway"
sequence:
option: moderate
option: standard
fan_speed: balanced
segments: 17
# Clean livingroom
- conditions:
- condition: state
state: "Clean livingroom"
sequence:
option: moderate
option: standard
fan_speed: balanced
segments: 19
# Clean diningroom
- conditions:
- condition: state
state: "Clean diningroom"
sequence:
option: moderate
option: standard
fan_speed: balanced
segments: 20
# Clean bedroom
- conditions:
- condition: state
state: "Clean bedroom"
sequence:
option: moderate
option: standard
fan_speed: balanced
segments: 21
default: []
A new version of a card has just been released:
New platforms, generating icons, improved interface
It contains a lot of changes, including new 5 supported platforms:
- DeebotUniverse/Deebot-4-Home-Assistant
- Tasshack/dreame-vacuum
- romedtino/simple-wyze-vac
- BenjaminPaap/home-assistant-myneato
How can I get the status, battery, fan speed etc removed ?
and how do I get rid of the zone cleanup (map mode options)
tiles: []
map_modes: []
preset_name: Live map
entity: vacuum.roborock_s6_maxv
map_source:
camera: camera.roborock_s6_maxv_map
crop:
left: 1
right: 1
top: 30
bottom: 40
calibration_source:
camera: true
map_locked: true
tiles: []
map_modes: []
map_transformation:
scale: 2
trim:
left: 2
right: 2
top: 2
bottom: 2
colors:
color_map_outside: [29, 29, 29]
card_mod:
style: |
#map-zoomer-overlay > div:nth-child(1) {
display: none;
- How do I get the map a little bigger ?
- Is it possible to make the buttons custom ? Or can I make them like my theme ?
- tried to make the background the same as my other cards, but itâs not ok. Whats wrong ?
I assume you use the custom Roborock integration.
- You can do it by increasing these values in your config:
You can also remove wholemap_source: camera: camera.roborock_s6_maxv_map crop: left: 1 right: 1 top: 30 bottom: 40
map_transformation
, it is a part of configuration of Map Extractor - Yes, everything is possible, here you have a description how to change colors
- There are 2 map backgrounds in this card: the first one is a part of map image, it has to be changed by the integration that provides the map camera. The second one is visible when you make map background transparent or when you slide the map away from the view. It can be changed using
map-card-zoomer-background
(card styling)
Ok. Thanks.
Map is bigger and background is ok.
Can you just give me a hint for the buttons ?
You have to be more specific for me to be able to give any specific hint
Lines to add to your theme:
map-card-secondary-color: "#ff0000" # icons background color
map-card-secondary-text-color: "#0000ff" # color of icons
map-card-primary-color: "#00ff00" # selected icon background color (in fan modes menu)
map-card-primary-text-color: "#ffff00" # selected icon color
