3_14
(Piotr Machowski)
July 22, 2023, 1:04am
1616
It means that the map has been shifted, you have to adjust zones.
You can change font size by adding following properties to your theme:
map-card-manual-rectangle-description-font-size
map-card-predefined-rectangle-label-font-size
map-card-room-label-font-size
map-card-predefined-point-label-font-size
To change font size you have to use card mod and apply appropriate style to .label-text
class
No, this is a value of state
attribute of vacuum entity, it is always set to “Charging” when the vacuum is docked
@3_14 Thanks. I was all set but the map shifted again. Is that common/stoppable?
3_14
(Piotr Machowski)
July 23, 2023, 7:07pm
1618
it usually happens when you move the docking station or change something in the room layout
Kenny78
(Davide)
July 28, 2023, 6:13pm
1619
I just added this card and works fine with xiaomi Mijia 1s, i love it!
I have a question:
My vacuum never stuck in rug till i use this cards, It seems less “smart” with carpet than xiaomi home app. I have to remove the rug because 100% it stuck in it ( wheels slip on the floor)
Is it possible? There is a fix(options to set)?
Thank you Piotr!
3_14
(Piotr Machowski)
July 28, 2023, 6:30pm
1620
I don’t think it is possible that your problem is related to the card…
Kenny78
(Davide)
July 28, 2023, 7:03pm
1621
I know that seems strange but…i will try to explain myself:
Mijia vacuum 1s had some limitation in Xiaomi home: never had “clean zone” and never had “clean x2 or x3” but now ,with this card, it is possible and it works! it could not be possible that some “command set” are different from “custom command” xiaomi home?
3_14
(Piotr Machowski)
July 31, 2023, 9:34am
1622
I don’t think so, but I’m not sure.
wifispray
(Wifispray)
July 31, 2023, 7:36pm
1623
Is there an easy way to turn the auto generate room config to map the rooms correctly. Currently just big boxes around the rooms.
3_14
(Piotr Machowski)
July 31, 2023, 9:29pm
1624
You have to change outline
configuration for every room that you want to adjust.
# Setup Platforms
The purpose of setup platforms is to make it easier to retrieve coordinates for other platforms.
### Getting coordinates
To get coordinates of zone, point or outline you have to:
1. Open dashboard in edit mode
2. Open card editor
3. Choose appropriate setup platform according to platform you use in card
<table>
<tbody>
<tr>
<th>Setup integer</th>
<th>Setup decimal</th>
</tr>
This file has been truncated. show original
wifispray
(Wifispray)
July 31, 2023, 9:49pm
1625
3_14:
outline
So kind of draw a number of boxes around the area and take all those coordinates? Sorry just a bit confussed by the instructions, which im sure is me being stupid.
3_14
(Piotr Machowski)
July 31, 2023, 9:52pm
1626
Choose appropriate mode from dropdown according to desired shape
Zone → “Zone cleanup”
Point → “Pin & Go”
Outline → “Path”
Selecting a “Path” option will create a list of pairs which can be used as an outline
For things like Sensors, Filter, Main Brush, and Side Brush, my vacuum supplies attributes for both hours and percentage. The card seems to be picking up the percentage attribute, but using hours as the unit. What’s the simplest way to correct this?
3_14
(Piotr Machowski)
August 1, 2023, 9:59pm
1628
Which integration do you use? Please attach your card config
I’m using the Dreame integration (GitHub - Tasshack/dreame-vacuum: Home Assistant integration for Dreame Gen2 Lidar robot vacuums with map support ) and here is my config:
type: custom:xiaomi-vacuum-map-card
vacuum_platform: default
entity: vacuum.dreamebot_d10_plus
map_source:
camera: camera.dreamebot_d10_plus_map
calibration_source:
camera: true
map_modes:
- template: vacuum_clean_zone
max_selections: 10
repeats_type: EXTERNAL
max_repeats: 3
service_call_schema:
service: dreame_vacuum.vacuum_clean_zone
service_data:
entity_id: '[[entity_id]]'
zone: '[[selection]]'
repeats: '[[repeats]]'
- template: vacuum_clean_segment
max_repeats: 3
service: dreame_vacuum.vacuum_clean_segment
service_data:
segments: '[[selection]]'
predefined_selections:
- id: 1
outline:
- - -750
- 3600
- - -750
- 5800
- - 1850
- 5800
- - 1850
- 3600
- id: 2
outline:
- - -7800
- 2500
- - -7800
- 5950
- - -4700
- 5950
- - -4700
- 2500
- id: 3
outline:
- - -8050
- -1250
- - -8050
- 2500
- - -1100
- 2500
- - -1100
- -1250
- id: 4
outline:
- - -1200
- -1250
- - -1200
- 2200
- - 1950
- 2200
- - 1950
- -1250
- id: 5
outline:
- - 400
- 1350
- - 400
- 3150
- - 2000
- 3150
- - 2000
- 1350
- id: 6
outline:
- - -4700
- 2200
- - -4700
- 5300
- - 400
- 5300
- - 400
- 2200
- name: Clean Spot
icon: mdi:map-marker-plus
max_repeats: 3
selection_type: MANUAL_POINT
service: dreame_vacuum.vacuum_clean_spot
service_data:
points: '[[selection]]'
3_14
(Piotr Machowski)
August 2, 2023, 1:51am
1630
Try the following config instead:
vacuum_platform: Tasshack/dreame-vacuum
map_source:
calibration_source:
camera: true
map_modes:
- id: 1
outline:
- - -750
- 3600
- - -750
- 5800
- - 1850
- 5800
- - 1850
- 3600
- id: 2
outline:
- - -7800
- 2500
- - -7800
- 5950
- - -4700
- 5950
- - -4700
- 2500
- id: 3
outline:
- - -8050
- -1250
- - -8050
- 2500
- - -1100
- 2500
- - -1100
- -1250
- id: 4
outline:
- - -1200
- -1250
- - -1200
- 2200
- - 1950
- 2200
- - 1950
- -1250
- id: 5
outline:
- - 400
- 1350
- - 400
- 3150
- - 2000
- 3150
- - 2000
- 1350
- id: 6
outline:
- - -4700
- 2200
- - -4700
- 5300
- - 400
- 5300
- - 400
- 2200
- template: vacuum_clean_spot
nisay
August 5, 2023, 5:44pm
1632
I have a Roborock S6 and I cannot select “Path”. Is this only the case with newer Roborock models?
If yes, how can I set the coordinates of the rooms without zones?
gsca075
(SandroC)
August 9, 2023, 6:13am
1633
Using the camera for valetudo vacuums the calibrations data are automatically provided to the card of @3_14 this probably can be the easy way to use valetudo vacuums in home assistant.
3_14
(Piotr Machowski)
August 9, 2023, 9:05am
1634
Definitely! I didn’t know this integration
gsca075
(SandroC)
August 11, 2023, 5:43am
1635
Dear Piotr, this valetudo camera was inspired by your outstanding work linking and trying supporting the best vacuum card ever made for HA (yours) to this modest project of mine. I do really appreciate your work and I would really wish we could somehow cooperate with you. I guess anyhow we could move this discussion on on appropriate channels. Thanks for your great work.
Kyar
August 15, 2023, 11:50am
1637
Hello @3_14 ,
How can I zoom my map automaticly ? I need to x2 to be correct all time.
Thanks you
