Thankyou! I never scrolled down enough on documentation to see you could change colours!!
Got it sorted
Got it sorted
Hello all.
Im new on forum. So hope im posting in correct place.
Im using Vacuum Map Card.
I use Roborock S8.
I got working mop mode change in card using service call(vacuum.send_command) and sending parameters 301-303.
Does anyone know how to change mop intensity modes. What parameters i need to use?
Use this integration, it should work out of the box
Hello Piotr.
I am using Roborock integration from Hacks.
But I seem not find any documentation how to get mop intensity modes changed.
I did get mop modes button working by changing code little in vacuum map card.
- menu_id: mop_mode
icon: mdi:map-marker-path
label: Standard
conditions:
- entity: vacuum.roborock_s8
attribute: mop_mode
value: standard
tooltip: Change mop route
tap_action:
action: call-service
service: vacuum.send_command
entity_id: vacuum.roborock_s8
service_data:
command: set_mop_mode
params: 300
- menu_id: mop_mode
label: Deep
conditions:
attribute: mop_mode
value: deep
tap_action:
service_data:
params: 301
- menu_id: mop_mode
label: Deep+
conditions:
attribute: mop_mode
value: deep_plus
tap_action:
service_data:
params: 303
Mop mode and water box mode menus should be generated automatically when appropriate entities are available. Have you chosen the matching vacuum platform?
It did not work for me first time when I choose vacuum platform. Thatās why I went with āsend commandā platform. Now I reinstall all from beginning. It works now when choose correct vacuum platform.
Thank you very much for your help.
Hopefully someone can point me in the right direction. Iām having an issue with setting up a predefined point. I set up my own zones and those are working fine, and I can send the vacuum to a spot using the manual point, however when I try to use the predefined point I set up I get a popup saying āNo selection providedā. Iām using the Hypfer/Valetudo integration. Hereās the config:
- name: Empty Spot
run_immediately: false
coordinates_rounding: true
coordinates_to_meters_divider: 100
selection_type: PREDEFINED_POINT
max_selections: 5
repeats_type: NONE
max_repeats: 5
service_call_schema:
service: mqtt.publish
evaluate_data_as_template: true
service_data:
topic: broadway/mainfloor-roborock/GoToLocationCapability/go/set
payload: '{ "coordinates": { "x": [[point_x]], "y": [[point_y]] } }'
predefined_selections:
- position:
- 2380
- 2800
label:
text: Empty Spot
x: 2380
'y': 2800
offset_y: 30
icon:
x: 2380
'y': 2800
Iāve even tried replacing [[point_x]]
and [[point_y]]
with the actual coordinates and still get the same error. Done some searching and donāt see anyone else with the same issue so totally stumped here.
I assume you have selected the point on the map?
Ah, Iām an idiot! Knew it had to be something simple. I was just selecting Empty Spot
from the drop down and hitting the go button. Just selected it and tried again and it works now. Thanks for the fast response!
Is it possible to select and run favourites from the Zone selection dropdown?
I tried adding 2 favourites to the code and call to run them by pressing the button, but it does not seem to work. Thought it would work with run_immidiately: true
map_modes:
- name: ZonstƤdning
icon: mdi:select-drag
coordinates_to_meters_divider: 1000
selection_type: MANUAL_RECTANGLE
max_selections: 20
repeats_type: EXTERNAL
max_repeats: 3
service: dreame_vacuum.vacuum_clean_zone
service_data:
zone: '[[selection]]'
repeats: '[[repeats]]'
entity_id: '[[entity_id]]'
predefined_selections: []
variables: {}
- name: SegmentstƤdning
icon: mdi:map-marker-plus
selection_type: MANUAL_POINT
max_selections: 999
max_repeats: 3
service: dreame_vacuum.vacuum_clean_spot
service_data:
points: '[[selection]]'
variables: {}
- name: Moppa
icon: mdi:water
run_immediately: true
service: button.press
service_data: {}
entity_id: button.robotdammsugare_shortcut_2
- name: Moppning efter sopning
icon: mdi:water-plus
service_data: {}
entity_id: button.robotdammsugare_shortcut_3
Is this possible?
And is it possible to change the color of only one of the icons (Play, Pause, Stop) with something like this?
card_mod:
style: >
:host
.tile-play_button {
background-color: orange!important;
run_immidiately
doesnāt trigger service call by choosing an entry in dropdown - it is triggered on a selection of ātargetā on a map
Something like this:
:host
.icons-list > :nth-child(5) > :nth-child(1) > :nth-child(1) {
background-color: rgba(255, 173, 0, 0.8);
(source)
Hmmā¦ canāt make it work. Hereās my complete style for card-mod, even tried !important;
card_mod:
style: >
:host .icons-list > :nth-child(5) > :nth-child(1) > :nth-child(1) {
background-color: red!important;
ha-card {
box-shadow: none;
background: none;
border-style: none;
} {% if ( (states("sensor.robotdammsugare_main_brush_time_left")) |
float(0) < 1 ) %}
:host
.tile-main_brush-wrapper {
outline: 3px solid orange;
{% endif %}
Is it possible to use this menu/drop down for the shortcut button? Or should I try to create another dropdown?
This code should change the background color of 5th icon. Maybe you donāt have 5 icons?
Iām not sure what you mean
True, it does work, but when the buttons are collapsed (when it is not running) it will not work properly. Is it possible to address a button specifically, like you can address a tile?
I have a few shortcuts created in the app for my vacuum. These are available via Home assistant as a button. I need a way to select a shortcut and run it. And I thought the Zone dropdown would be a good place to put it.
However I canāt manage to make it click the button when selecting it from the dropdown. And as you say, it is because it expects a selection on the map.
Are there any other good workarounds for this?
No, it is not possible at this moment.
You can add them as icons, is it ok?
