Thanks for you answer, that seem to be a good solution, I will definitely go for.
However, I have actually 4 camera entities, 1 for the “current” map, on which I get to see the actual passes progress of the robot. And another 3 for each floor, where there will not be live progress.
So should I create one preset with “current” camera, without any set of rooms, call it “Live view”, and then 3 additional preset for each room, with their sets of rooms each?
That depends on your preferences ![]()
[EDIT - I figured it out]
Hi there,
This is really a great card - the functionality and the documentation is amazing!
I have an old roborock that I’m trying to get sorted on HA. I have a png image which is a snap generated from the valetudo camera system, and my calibration points on said map.
My question is that the map doesn’t seem to render: My guess is that I am not pointing it to the correct image?
The file does seem to be there though:
What am I doing wrong?
Hi, I’am struggling with the rooms config.
When I press the ‘GENERATE ROOMS CONFIG’ button in the card nothing happend. The config stays the same.
This is my card config:
type: custom:xiaomi-vacuum-map-card
map_source:
camera: camera.dreamebot_z10_pro_map
calibration_source:
camera: true
entity: vacuum.dreamebot_z10_pro
vacuum_platform: Tasshack/dreame-vacuum
The card ist not nested in any other card(s).
Dreame Z10 Pro over Xiaomi Account
Dreame: v1.0.4
xiaomi-vacuum-map-card: v2.2.2
HA: 2024.7.1
Thanks!
Thanks for this amazig plugin! I have a Roidme Eve Max Robot. Does Vacuum Interactive Map Card support this Robot?
Model: roidmi.vacuum.sdj60
Im getting an “TypeError: argument of type ‘NoneType’ is not iterable” Error when trying to add my robot.
camera:
- platform: xiaomi_cloud_map_extractor
host: ‘xxxx.xxx.x.xx’
token: ‘xxxx’
username: ‘xxxx’
password: ‘xxxx’
draw: [‘all’]
force_api: roidmi
attributes:- calibration_points
Hi Guys, I am a new member here and not an expert on Home Assistant.
I am having Xiaomi m1s and works ok when using zone clean up - for example.
Issue is when I using room cleaning and when I select the room and press start, it says Success! but nothing happens.
Attached is my Config file.
map_source:
camera: camera.xiaomi_cloud_map_extractor
calibration_source:
camera: true
entity: vacuum.roborock_vacuum_m1s
vacuum_platform: default
map_modes:
- template: vacuum_clean_zone
- template: vacuum_goto
- template: vacuum_clean_segment
predefined_selections:
- id: '16'
icon:
x: 24575
'y': 24300
label:
text: Hodnik
x: 24575
'y': 24300
offset_y: 35
outline:
- - 22508
- 24510
- - 26211
- 24510
- - 26211
- 25533
- - 22508
- 25533
- id: '17'
icon:
x: 29650
'y': 24600
label:
text: Dnevna
x: 29650
'y': 24600
offset_y: 35
outline:
- - 26216
- 22335
- - 30347
- 22335
- - 30347
- 25828
- - 26216
- 25828
- id: '18'
icon:
x: 24575
'y': 26975
label:
text: Kuhna
x: 24575
'y': 26975
offset_y: 35
outline:
- - 23205
- 26152
- - 25389
- 26152
- - 25389
- 28242
- - 23205
- 28242
- id: '19'
icon:
x: 28300
'y': 27475
label:
text: Jedilnica
x: 28300
'y': 27475
offset_y: 35
outline:
- - 25341
- 25846
- - 30429
- 25846
- - 30429
- 28830
- - 25341
- 28830
- id: '20'
icon:
x: 22250
'y': 23250
label:
text: Kopalnica
x: 22250
'y': 23250
offset_y: 35
outline:
- - 21000
- 22400
- - 23500
- 22400
- - 23500
- 24100
- - 21000
- 24100
- id: '21'
icon:
x: 22700
'y': 24300
label:
text: Room 21
x: 22700
'y': 24300
offset_y: 35
outline:
- - 21900
- 24100
- - 23500
- 24100
- - 23500
- 24500
- - 21900
- 24500
- id: '22'
icon:
x: 21625
'y': 26650
label:
text: Pisarna
x: 21625
'y': 26650
offset_y: 35
outline:
- - 20750
- 24516
- - 22565
- 24516
- - 22565
- 28808
- - 20750
- 28808
To me all looks ok but not sure why not starting it.
I think your model is not supported at this moment
Which integration do you use to add the vacuum to HA?
Thank you very much for confirmation. In HA I am using Xiaomi Miio - along this camera integration and card.
Hi All,
There are none obstacles in the Roborock app (iOS)
I try to remove them also in the card. Without success
- Removed the integration totally.
- Restart HA
- Reinstall the integration again using HACS
This didn’t help.
Is there a location that stores the image ?
Try this config:
Which integration do you use to get map?
I use this integration:
And this integration for the vacuum itself
Have some more options then the core version in HA
Thank you very much for your effort. Appreciate it.
It works now.
Does this card work with core Roborock integration?
I get ‘invalid calibration’ message when using this integration.
I get these “Missing Configuration: map_image or map_camera” errors once in a while, any ides? Most of the time it´s working great.
@poudenes
Map image is provided by the integration, so you have to ask your question there.
@Mosher
No, it does not (at this moment)
@Fifthy
it must be some caching issue or double installation. Version v1.X.X used these properties
I noticed that the ip for the vacuum had changed so it was the wrong local ip set in configuration.yaml, might it have something to do with that?
Does the map integration pull the map locally or from the cloud?
Integration sends a command to the vacuum to upload the map to the cloud and then it downloads the map from the cloud. So yes, correct IP address is required for the integration to work
