Invalid config for [template]: invalid template (TemplateSyntaxError: unexpected char ‘’’ at 21) for dictionary value @ data[‘sensor’][0][‘state’]. Got ‘{{climate.control_zo1’, ‘current_temperature’)}}’ value must be one of [‘measurement’, ‘total’, ‘total_increasing’] for dictionary value @ data[‘sensor’][0][‘state_class’]. Got ‘‘measurement’’. (See /config/configuration.yaml, line 63).
Invalid config for [template]: invalid template (TemplateSyntaxError: unexpected char ‘‘’ at 2) for dictionary value @ data[‘sensor’][0][‘state’]. Got ‘{{‘climate.control_zo1’, ‘current_temperature’}}’ value must be one of [‘measurement’, ‘total’, ‘total_increasing’] for dictionary value @ data[‘sensor’][0][‘state_class’]. Got ‘‘measurement’’. (See /config/configuration.yaml, line 63).
Yes, same here: (and I can’t open the android app)
First occurred: 14:03:21 (36 occurrences)
Last logged: 15:33:13
Unexpected error fetching multimatic_quick_mode data: Cannot get token at https://smart.vaillant.com/mobile/api/v4/account/authentication/v1/token/new, status: 503, response: Service Unavailable,payload: None
i share my experience:
on my side, i used first multimatic app (VRC700 + VR920).
i installed the thomas integration in my HA (still the case, still working when the vaillant cloud is ok ).
by curiosity i installed senso app. that works and this is still ok in HA.
@tgermain is there a service call to “Heat Warm-Water Once?” which is availabel in the Multimatic App. I am not sure from the documentation which option to call
The water_heater.control_dhw entity only allows to select Auto,On,Off,and Temperature … so seems to be adiffernet service call
after not having dealt with the issue for some time, now the conclusion of the problem. Some of the inverted commas / qutoes were wrong. Here is the version that runs.
I would like to display the return temperature of the heating circuit water from the underfloor heating. But I don’t see it in the app. Can the integration read it out anyway?
