I’ve installed Valetudo in my Xiaomi Vacuum 2.Gen. The Valetudo Web UI and Home Assistant integration works well.
But I’m a little confused about the live maps.
Home Assistant created an entity called camera.rockrobo_map. I add this entity to lovelace as a Picture Entity card. The map appears on the frontend. But why do I have to use the ICantBelieveItsNotValetudo-Addon also? Where is the different between the camera.rockrobo_map and the ICantBelieveItsNotValetudo-Addon??
Thanks for your help
