About:
Extract the maps for rooted Vacuum Cleaners running Hypfer, Congaduto / RE (rand256) Valetudo Firmware to Home Assistant via MQTT, easy setup thanks to HACS and guided configuration via Home Assistant GUI. This integration was inspired and developed due to the great work of Piotr Machowski it simply render the vacuums maps.
It is an unofficial repo and is not created, maintained, or in any sense linked to valetudo.cloud
Setup of this camera, that decode the vacuum maps and render it to Home Assistant, is straight forward and fully compatible with all home assistant possible installations type.
It works with all flashed and supported Valetudo Hypfer, RE(rand256) or Congaduto vacuums .
Features:
Rendering Virtual Restrictions, active zones, active segments and also obstacles positions.
Automatically Generate the calibration points for the lovelace-xiaomi-vacuum-map-card to ensure full compatibility to this user-friendly card.
Automatically Generate rooms based configuration when vacuum support this functionality, this will allow you to configure the rooms quickly on the lovelace-xiaomi-vacuum-map-card.
The camera can take automatically snapshots (when the vacuum idle/ error / docked) the snapshot can be saved with a custom name and location via snapshot services in home assistant as well.
Change the image options directly form the Home Assistant integration UI with a simple click on the integration configuration.
The options menus are design to work on the mobile phones without scrolling as much as possible.
Image Rotation: 0, 90, 180, 270 (default is 0).
Trimming automatically the images improved the configuration of the images, you can add the margins around the images, the images are automatically trimmed to the minimum size.
Base colors are the colors for robot, charger, walls, background, zones etc.
Rooms colors, Room 1 is acrually also the Floor color (for vacuum that do not supports rooms).
It is possible to display on the image the vacuum staus.
Transparency level custom setup for all elements and rooms.
This integration make possible to integrate multiple vacuums as per each camera will be named with the vacuum name (example: vacuum.robot1 = camera.robot1_camera.. vacuum.robotx = camera.robotx_camera)
The camera as all cameras in HA supports the ON/OFF service, it is possible to suspend and resume the camera streem as desired.
We did recently also start to implement CPU and Memory reporting to HA so that the threads can be better handled in Home Assistant Virtual Environments.
Auto Zoom the segments under cleaning if the vacuum support the segments. This future is available as an option from V1.5.9
If the vacuum support Obstacles View it render the obstacles phots when available.
Recently added as supported form some vacuums, materials and carpets rendering.
And is also possible to get the status of the vacuums display on the status text with the same language the UI of Home Assistant is setup to use (for more translations do not hesitate to contribute).
Notes:
This integration is developed and tested using a PI4 with Home Assistant OS fully updated to the last version, this allows us to confirm that the component is working properly with Home Assistant. Tested also on Proxmox and Docker Supervised āproductionā environment (fully setup home installation).
Visit us and report any issues you face, welcome also suggestions or improvements requests in our:
I tried your project on current HASS and it basically works with a Dreame Z10 Pro, even if it is not on the supported list of devices. It receives the map data from the Valetudo-driven robot through MQTT and displays it. Yet, when cropping and trimming the map Home Assistant keeps restarting.
Is that an expected bahaviour? Debug log doesnāt give much intel as to why the
Once you can confirm the version of the camera you are using will start the investigation or try to reproduce the phenomena you face. We didnāt release (except in some beta test) any version causing HA to reboot. The cropping factor was introduced because some of the maps produced from the Vacuums are quite big to handle (causing instability). Platform wise we will later on introduce an Intel based version of this component as per we will use OpenCV instead of PIL (currently on PI4 or Home better Assistant OS it isnāt possible to setup OpenCV just by importing it). In general all Valetudo Vacuums could be supported will add Dreame Z10 Pro to the list too
@digodigo thanks to you⦠we did work a little in the last week on checking more in deep the camera performances and now we did overcome also the limits we had on our architectureā¦we did create our on library (similar to the OpenCV one) and we did improve drastically the performance of the integration. We strongly recommend to update to version v1.4.3 when not yet done.
@gsca075 great work! Setting it up was, well, not a breeze, but straightforward.
A few ideas:
Automate trimming. This should be relatively straightforward to do, just need to find the position of the leftmost/topmost/rightmost/lowest pixel position of a wall object being drawn, add a configurable padding to that, and set the trim to those edges. This way the trimming doesnāt need to be manually re-configured every time the map updates.
It would be nice to have an option for exporting the various layers within the Valetudo data into separate camera objects - one for the walls, one for the rooms, one for the vacuum position, one for the dock position, etc., allowing the user to freely assemble the layers into an overview via e.g. the Picture Elements card
Vector rendering. I understand that the Valetudo map data is a compressed bitmap without any anti-alias, meaning just by changing the drawn pixel size (e.g. instead of a 1x1 pixel, one draws a 4x4 unit), it can be scaled up to great lengths. This should also mean that this bitmap can be processed into a vector graphic using e.g. drawsvg (which has a similar API to PIL), then return the appropriately scaled bitmap to the camera entity, while also making the raw SVG content available to be used by e.g. ha-floorplan
we should auto trim the image, by default auto trim ON or OFF manual trimming as it is now⦠, this would give the best options to everyone do you agree?
We should separate the output image if desired giving the option to store the different layers anyhow the robot position is actually available as attribute, could add the dock position⦠if the idea is to use the camera to create a picture element⦠(and I think it is a cool idea) would it be enough to extract the floor (segments) and walls => this data can be exported as SVG as well.
We use numpy to draw the elements and Valetudo uses compressed pixels, this means we already draw the image as you say kind of Vector way (and actually numpy does this as OpenCV that isnāt compatible on all HA installations). The cameras in HA so far I know can only render the jpeg or pil or bitmap images⦠we chose Numpy because it basically runs on all installation of Home Assistant (ensure compatibility)ā¦
In geneal⦠this camera purpose is to use the vacuums⦠so okay for 1 and 2⦠we could implement this⦠it will take a little time anyhow because right now we are trying to support also the Valetudo Re vacuums.
So⦠after v.1.5.0 is released we will start to work on itā¦
Would you open a discussion on our repository for your ideas please?
Iād say make auto trim default, and supply an appropriate default padding (eg 50px, or whatever units the current trim fields take). Then you can make it an option on the config page, and a collapsible section for manual trim tuning.
Yep, thatās the idea Iām going off of The Xiaomi Vacuum Card repo has a good example on such picture-element overlaying techniques, and Iāve managed to get it mostly working:
But this obviously requires a bunch of manual tinkering (ignore some slight discrepancies e.g. the balcony door/window edges not lining up, the floor plan isnāt perfect). Having separate layers for the walls, the rooms, the robot and the dock would allow one to compose a layout they want. But of course for ready-made cards, youād need a full map too⦠So it is best to have the ability to create multiple cameras would come handy.
I get why numpy is being used. Iām also aware that HA, at this moment, does not support vector images for cameras - this is actually something I wanted to bring up for some time, and will ask on Discord to see if it can get any level of traction. Such vector approaches would be useful as vector images can contain tons of attributes, can be easily generated/drawn (thereās even open source JS libraries that allow rudimentary WYSIWYG vector editing! Imagine, in a few releases, if we had full vector support for a new āfloorplanā camera entity (sub)type, making it possible to easily create a visual representation of the home that HA can use, like the aforementioned floorplan card approach, but all built in).
Iāll open a discussion on the git repo later today!
@fonix232 I think we are talking about a kind of home advanced panel here⦠well⦠the idea is really cool. and yes at this point will do some experiment to ācrop automaticallyā the images, and then apply the trims as you say keeping the configuration page availabe. You see the Valetudo maps are 52105210 pixels or 7xxx7xxx and we do have a pixel_size that can scale the image⦠itās quite a big challenge but you would like in general to get an image where you can control other HA elements⦠such as lights, and other home appliance in just one ācardā⦠using SVG could actually lead to other applications such as scanning floors and importing the result to CADās ⦠I think will do a stand alone project for this to begin⦠therefore⦠challenge acceptedā¦
"Why does the zone cleaning feature not seem to work as expected, and Iām unsure if Iām addressing my question in the right place? My current configuration looks like this:
@Flodo1987 Iām not sure if I understand it correctly. Anyhow I just got a S50 and I found out a couple of ābugsā on the integration that I count to solve with the next release, the zone clean or rooms cleaning was not properly shown on the map but the vacuum went to the right position and performed as it should. In your config:
internal_variables:
topic: valetudo/your_topic
should be replaced with the valid topic that you should see in the camera attributes. According to your vacuum entity⦠it should be something like:
internal_variables:
topic: valetudo/Dustin
Please check on the attribute of the camera vacuum_topic, this parameter is case sensitive and if not set correctly in the card this could explain why the zone_clean or go_to function do not work as expected.
Hope this helps.
I have another question.
Is it possible to initiate room cleaning with Alexa using voice commands?
Iām not sure if Iām asking this question in the right place.
Thank you in advance for any assistance!
yes it is possible but you need to write some automation / script in Home Assistant.
There is to copy the MQTT command the card send and to the vacuum and use the āMQTT: Publishā service in Home Assistant.
The script will be then exposed to Alexa from HA.
Then you can use the Alexa app to or your echo to to trigger the script.
If you have motions sensor in your room you can also trigger the robot to pause when someone is the room and resume when the room is free⦠actually if you predefine zones or points you could in theory voice command the robot to go or do whatever.
The card is really useful to get out the correct payload (in edit mode you can ācopy service callā) to use use in the service you got to figure out how to translate it. and basically tell to Alexa what to do⦠run the script in HA⦠there are also a couple of example in the Valetudo Cloud
Okay, then I havenāt understood how to do it yet.
Iāve been looking at it for a few days now and testing some things, but when I copy the example and try to create a script with it, I get an error, specifically:
āMessage malformed: extra keys not allowed @ data[āserviceā].ā
And now Iām stuck and donāt quite understand how to resolve it."
@Flodo1987 no worry I will soon put on the repository some template or script example so that you can have a look at them and probably will be interesting also to others
I did some automation long ago and at that time having a V1 I had to use the zones⦠I just need to look back on my config and will share it, if I can still find them
Look I just run the example I passed you⦠and did work with my vacuum. There is and it is a little complicated now to enable the script or automation you will write āclean bedroomā or whatever on the settings of Home Assistant to be exposed to Alexa. The script must have a service call (edit YAML) similar to the one I posted above. The robot started (my S5) without any problem the only think is to use the room ID #number and topic valetudo JustForDemonstration as you learned⦠but the rest copy past
