Valid Configuration, emulated hue sees groups, but can't see switches
I’m running Hassbian, and I recently upgraded HA to 60.1, but I did not make any changes to my yaml files. Now my emulated hue is inconsistent.
RaspberryPI 3 running superheterodyne RF transmitter / receiver,
Echo Dot v2 controlling EtekCity rf plug-in outlets (“switches”),
Emulated hue is enabled, and everything worked for a year with no problems and no other emulated hue detail added in config yaml.
Now,
My config comes back Valid when checked.
I login to Home through my web browser, and everything works. All switches show up, and they toggle fine.
When Alexa scans for devices, it finds all switches as they appear in config yaml.
Alexa *does turn on “all switches” (considered a group in HA) when asked.
Alexa *cannot turn on individual switches when asked; says it didn’t find the given switch.
(myaddress):8300/description.xml shows HASS Bridge
(myaddress):8300/api shows 404 file not found
I’ve booted, re-booted, forgot, and re-scanned everything several times. I don’t want to re-install my HA image if I don’t have to. Am I overlooking anything obvious? Anybody else have similar problems?
Thanks!
