What is the valid syntax for the symbol meter1 in this post Switch-Bot API integration - #15 by fLegmatik? Can I use foo_bar instead? What about foo_bar_baz? Can I rename Meter JSON to FOfdsioaufsdio43 XML, and so on?
My names originally have spaces in them (for example Big Apple), which I have already converted via jq to big_apple, but that still doesn’t seem enough. In short, please explain the format and the semantics of the undocumented name parameter. It’s also possible the code of this user is wrong.
