I’m trying to get the current power of my tp link smart plug from my dishwasher to check if it goed below a certain power usage (and turn it off then). I’m getting the error with the state that the value cannot be processed as a number. When I try to put it in the template editor, the correct value is displayed (0.00, cause it’s off right now). I’ve searched around a bit here and tried to modify a few things, but none was working. Here’s my code I have right now:
sensor: should not be indented below tplink. It should be hard up against the margin and there should only be one sensor: in your configuration.yaml file.
Template sensors are not options for the tplink integration. They are an integration in their own right.
Please don’t post pictures.
If you insert preformatted text (As Tom did) this is much smaller and we can read it, fault find and cut and paste it into our template editors. Please read the sticky at the top of the forum (by Tinkerer)
You shouldn’t have to apologize. This documentation clearly states “In order to get the power consumption readings from a TP-Link HS110 device, you’ll have to create a template sensor.”
