Value exposed in Zigbee2MQTT but not in HA
Hey, I just bought a bunch of radiator valves Sonoff TRVZB. I connected them to my server via Zigbee2MQTT. All good so far. In Zigbee2MQTT I can see the values as “local_temperature” and “running_state” but I can’t find those values in Home Assistant. What should I do to fix this? Other values I can see in HA but this not. How can I bring those values to HA? I need them in order to do the automation I planned.
One reason is often not using the latest versions of HA and Zigbee2mqtt
I use Z2M 1.39.1 and HA 2024.8.3. I observe that in Z2M under Reporting I can see all 3 values that are missing in HA configured under a Cluster. And in HA I can see all those 3 values under a single entity, but I need them separately.
Use a template sensor to bring them out separately
All good, thanks for tip. Solved!
