I’m complete new to Home Assistant and struggle already on a small job.
Background:
In installed HA OS on a Pi4, installed the add-ons Mosquitto broker und Zigbee2MQTT.
Sucessfull paired with a Zigbee Thermostat.
I can controll it over the Dashboard, thats working fine.
Issue:
I created two scenes to adjust the temperature, one for the night and one for the day.
I tried it directly over HA and a second time over the Mosquitto broker add-on.
But when I excute the scenes the new target temperature is not set.
The Thermostat is shortly lightning up, but not changing the temperature.
What did I wrong?
Many Thanks from a Newbie
Thats how the scene look like in scenes.yaml:
<sub>- id: '1666947366821'
entities:
climate.thermostat_arbeitszimmer:
hvac_modes:
- 'off'
- auto
- heat
min_temp: 5
max_temp: 30
target_temp_step: 0.5
current_temperature: 21.4
temperature: 21
friendly_name: Thermostat Arbeitszimmer
supported_features: 1
away_mode: 'OFF'
battery: 35
child_lock: UNLOCK
color_mode: xy
current_heating_setpoint: 21
linkquality: 255
local_temperature: 21.4
preset: manual
system_mode: heat
valve_detection: 'ON'
window_detection: 'ON'
state: heat
icon: mdi:home-thermometer
metadata:
entity_only: true
- id: '1666949069015'
entities:
hvac_modes:
- 'off'
- auto
- heat
min_temp: 5
max_temp: 30
temperature: 17
away_mode: 'OFF'
battery: 35
child_lock: UNLOCK
color_mode: xy
current_heating_setpoint: 17
linkquality: 255
position:
preset: manual
running_state:
system_mode: heat
state: heat
icon: mdi:home-thermometer-outline
metadata:
entity_only: true
</sub>
