Value template changes in 2023.5 - Affecting old template sensors
Since 2023.5, 2 old value templates of mine no longer work. Read the docs, tried to make the changes HA fails the check.
  sensors:
    multiplus_inverter_state:
      friendly_name: "Inverter mode"
      unit_of_measurement: "State"
      entity_id: sensor.multiplus_inverter_state_numeric
      value_template: >-
        {% set mapper =  {
            '0' : 'Off',
            '1' : 'Low Power',
            '2' : 'Fault',
            '3' : 'Bulk',
            '4' : 'Absorbtion',
            '5' : 'Float',
            '6' : 'Storage',
            '7' : 'Equalize',
            '8' : 'Passthru',
            '9' : 'Inverting',
            '10' : 'Power Assist',
            '11' : 'Power Supply',
            '252' : 'Bulk Protection' } %}
        {% set state = states('sensor.multiplus_inverter_state_numeric') %}
        {{ mapper[state] if state in mapper else 'Unknown' }}
So from how I read it, the ‘value_template’ needs to be changed to ‘states’, but that’s still not working.
Can anyone see what I am missing?
Just remove this.
Only sensors with numeric values can have a unit of measurement now.
If you want to convert it to the modern format (where the “state:” you were talking about is used), delete your sensor from your sensors.yaml file and put this in your configuration.yaml file:
template:
 sensors:
    - name: "Inverter mode"
      state: >
        {% set mapper =  {
            '0' : 'Off',
            '1' : 'Low Power',
            '2' : 'Fault',
            '3' : 'Bulk',
            '4' : 'Absorbtion',
            '5' : 'Float',
            '6' : 'Storage',
            '7' : 'Equalize',
            '8' : 'Passthru',
            '9' : 'Inverting',
Thank you for this. I copy pasta-ed what you did, and it passes the check but still fails and ends up in the logs. Getting this back:
Invalid config for [template]: expected dictionary for dictionary value @ data
Also why does it work in the config only and not the sensors yaml file?
I think there is a small indentation problem in the code.
Try this:
template:
  - sensor:
        state: >
          {% set mapper =  {
              '0' : 'Off',
              '1' : 'Low Power',
              '2' : 'Fault',
              '3' : 'Bulk',
              '4' : 'Absorbtion',
              '5' : 'Float',
              '6' : 'Storage',
              '7' : 'Equalize',
              '8' : 'Passthru',
              '9' : 'Inverting',
Also I made a copy paste mistake. Remove this
Even when removing this, its still complainging in the logs. I can’t figure it out. Incase it helps, here is the whole error message.
Logger: homeassistant.config
Source: config.py:868
First occurred: 8:33:26 AM (1 occurrences)
Last logged: 8:33:26 AM
Invalid config for [template]: expected dictionary for dictionary value @ data['sensors']. Got [{'name': 'Inverter mode', 'state': "{% set mapper = {\n '0' : 'Off',\n '1' : 'Low Power',\n '2' : 'Fault',\n '3' : 'Bulk',\n '4' : 'Absorbtion',\n '5' : 'Float',\n '6' : 'Storage',\n '7' : 'Equalize',\n '8' : 'Passthru',\n '9' : 'Inverting',\n '10' : 'Power Assist',\n '11' : 'Power Supply',\n '252' : 'Bulk Protection' } %}\n{% set state = states('sensor.multiplus_inverter_state_numeric') %} {{ mapper[state] if state in mapper else 'Unknown' }}\n"}]. (See /config/configuration.yaml, line 684).
Show your config as it is now.
This is it in configuration.yaml
template:
  - sensors:
        # entity_id: sensor.multiplus_inverter_state_numeric
        state: >
          {% set mapper =  {
              '0' : 'Off',
              '1' : 'Low Power',
              '2' : 'Fault',
              '3' : 'Bulk',
              '4' : 'Absorbtion',
              '5' : 'Float',
              '6' : 'Storage',
              '7' : 'Equalize',
              '8' : 'Passthru',
              '9' : 'Inverting',
#     # Inverter States, 0=Off;1=Low Power;2=Fault;3=Bulk;4=Absorption;5=Float;6=Storage;7=Equalize;8=Passthru;9=Inverting;10=Power assist;11=Power supply;252=Bulk protection
It should be:
template:
  - sensor:
Perfect, thank you.
I was switching between sensor/s while there were still some other issues and forgot to change it back.
Now to apply the same to the rest of my value templates.
@tom_l Can I check, I do look at breaking changes but I must have missed this.
A previous configuration that was
    sensors:
Now needs to be
template:
  - sensor:
      - name: "sensor 1"
        state: etc
      - name: "sensor 1"
        state: etc
[edit]
The docs suggest the old format should still work. Template - Home Assistant
It might be a different problem I am seeing.
