raenrfm
December 29, 2019, 5:11pm
1
I’m trying to take the values from my weather station which are posting to my mosquitto broker. The temperature is in F and the pressure is in inHg. I’m trying to use a value_template to convert these to MKS units or C and kPa respectively. I have battled with this for hours and it is not making any sense to me. I am new to HA so I’m probably missing something obvious, but any help would be appreciated. Here is my sensors.yaml:
- platform: mqtt
state_topic: "weather/soc"
unit_of_measurement: '%'
- platform: mqtt
name: "Indoor Temperature"
state_topic: "weather/inTempC"
unit_of_measurement: '°C'
- platform: mqtt
name: "Indoor Humidity"
state_topic: "weather/inHumidity"
- platform: mqtt
name: "Outdoor Temperature"
state_topic: "weather/outTemp"
unit_of_measurement: '°F'
- platform: mqtt
name: "Outdoor Humidity"
state_topic: "weather/outHumidity"
- platform: mqtt
name: "Barometric Pressure"
state_topic: "weather/pressure"
unit_of_measurement: 'kPa'
sensors:
outdoor_temperature_c:
friendly_name: "Outdoor Temperature"
value_template: "{{ (states('sensor.outdoor_temperature') | (float-32)/1.8) | round(1) }}"
barometric_pressure_kpa:
friendly_name: "Barometric Pressure"
value_template: "{{ (states('sensor.barometric_pressure') | (float+0.83)*3.38639) | round(1) }}"
raenrfm
2
Also the rounding is not working as expected.
VDRainer
December 29, 2019, 5:48pm
3
Read here
I’m using this to convert from F to C.
{{ ((states('sensor.temperature_f') | float -32) * 5 / 9) | round(1) }}
raenrfm
December 29, 2019, 11:51pm
4
Thanks, I think I had some missing brackets or in the wrong place, but for some reason my rounding is not working at all. I’m still getting temperature and pressure with all the sensor’s sig digits. Aside from the value_template is there something that needs to be done in the sensor panel itself?
VDRainer
December 30, 2019, 8:18am
5
Show us the code of the template please.
raenrfm
December 30, 2019, 1:58pm
6
This is in my sensors.yaml. Does it have to be in the configuration.yaml? I have a pointer to the sensors.yaml inside the configuration.yaml.
sensors:
friendly_name: "Outdoor Temperature C"
value_template: "{{ ((states('sensor.outdoor_temperature') | float - 32) * 5 / 9) | round(1) }}"
friendly_name: "Barometric Pressure kPa"
value_template: "{{ (states('sensor.barometric_pressure') | float + 0.83) * 3.38639 | round(1) }}"
VDRainer
December 30, 2019, 9:42pm
7
If you read the link to templating that i posted, you will see that
The default priority of operators is that the filter ( |
) has priority over everything except brackets.
so in the barometric template you round 3.38639 to 2 decimal places and then multiply it with (states(‘sensor.barometric_pressure’) | float + 0.83)
{{ ((states('sensor.barometric_pressure') | float + 0.83) * 3.38639) | round(1) }}
should work.
The temperature template works for me.
One tip:
Copy and paste your templates {{ .... }}
in Dev Tools/templates and you can play with them.
raenrfm
December 30, 2019, 9:56pm
8
yeah I discovered that utility but for some reason it’s not rounding off at all?? Weird.
