hi there.
im going nuts!
I have a onewire sensor entity_id: (sensor.2804146ce26aff_temperature) but that sensor is outside my watertank and is always 20 degrees C below the correct temperaturw. Therefor i want to make a template sensor adjusting this.
what i understand i cant use entity_id starting with numbers therfore the [’’] but i cant get it to work. when i try a different sensor that do not start with number it works.
im going crazy here
Can someone please tell me whats wrong in this template sensor?
You are missing the dot after your brackets, and you are using single quotes in single quotes. Single quotes in single quotes need a \ in front of them, or use double quotes with single inside. Otherwise, the software sees this as a string: '{{ states.sensor[', this as a variable: 2804146ce26aff_temperature, and this as a string: '].state | float + 20 }}'.
