Value Template Trigger Not Working
I have been tinkering with trying to set an input boolean with an automation, using a template as a trigger, and I’ve tried a few things. This is what I have as a trigger for the automation…
{{ 'warning' in state_attr('sensor.nws_alerts', 'state') | lower }}
Essentially, I want to set the input boolean state (of a “severe weather” input boolean) if any National Weather Service alerts contain the word “warning”. I had a severe thunderstorm warning yesterday, and nothing happened.
Anybody know what I’m doing wrong? I will also need to set the input boolean once the “warning” goes away.
Thanks, as always…
The attributes of the sensor contain information like this…
Title
Special Weather Statement - Severe Thunderstorm Watch
Event ID
https://api.weather.gov/alerts/urn:oid:2.49.0.1.840.0.59f7a454e9ebc6767abfaec2e1fcff13cbb4c212.001.1 - https://api.weather.gov/alerts/urn:oid:2.49.0.1.840.0.356e31e13eb1efd20c06ba265a2048ead6642693.001.1
Message type
Alert - Alert
Event status
Actual - Actual
Event severity
Moderate - Severe
Event expires
2023-09-08T16:30:00-04:00 - 2023-09-08T23:00:00-04:00
Display desc
> Headline: Strong thunderstorms will impact portions of southwestern Litchfield, southeastern Ulster and southern Dutchess Counties through 430 PM EDT Status: Actual Message Type: Alert Severity: Moderate
Etc...
Your template references an attribute called state that doesn’t exist in the sample data you posted.
Perhaps you want to check if the word warning exists in the title attribute?
{{ 'warning' in state_attr('sensor.nws_alerts', 'title') | lower }}
Thank you for this, it worked.
I remember seeing some of this discussion around when I initially set my configuration up, and much of mine is just copied from elsewhere. This is a long overdue piece of the puzzle for me, since my goal is to trigger a “Severe Weather” mode when an alert comes in to enable automating around that.
I just had another alert go active, and my input_boolean changed properly. Now I just need that input_boolean to clear when the alert is over… Figuring that out should about do it…
:+1:
