Hi all,
after spending an hour yesterday trying to understand the root cause for an unexpected result in a value template rounding I figured to bring it up here in the hope someone is able to help.
I have data coming into HA via MQTT. The JSON in question looks like that:
"DataRecord": [
"_id": "0",
"Function": "Instantaneous value",
"StorageNumber": "0",
"Tariff": "1",
"Device": "0",
"Unit": "Energy (10 Wh)",
"Value": "1444785",
"Timestamp": "2021-11-04T07:08:20Z"
Iβm using the following mqtt sensor definition in HA:
- platform: mqtt
name: "Waermepumpe test kWh"
state_topic: "mbusmeters/11011192434C1802"
unit_of_measurement: "kWh"
value_template: >-
{%- for rec in value_json.MBusData.DataRecord %}
{%- if (
( rec.Function == "Instantaneous value" )
and ( rec.StorageNumber == "0" )
and ( "Wh" in rec.Unit )
{{ rec.Value | float(0) / 1000 | round(2) }}
{%- endif %}
{%- endfor %}
What Iβm expecting from the input number β1444785β is the output β1444.785β and trying it out in the template editor gives exactly that result.
The sensor value though ends up with β1444.7850.0β and I canβt get my head around on why and where the 0.0 is getting added to the end. I tried multiple different versions of the sensor defintion, bracketing parts of the formula without luck - it always leads to the same result.
Leaving away the round btw gives me β1444785β as expected.
