Trying (and failing) to create a value template to determine whether a ‘target’ was detected within the previous 30s. I’m hoping to use this as a condition within an automation to throttle notifications when a target is detected.
State attributes of the entity are below, the attribute im looking to use is ‘last_target_detection’:
Spot on, thank you. One final question, given there is a time delay between starting Home Assistant and the entity attribute reporting a value the following error message is displayed in the logs.
Is there any way to prevent this error message from appearing?
TemplateError('ValueError: Template error: strptime got invalid input 'None' when rendering template '{{as_timestamp(now()) - as_timestamp(strptime(state_attr('image_processing.deepstack_object_ip_camera_north', 'last_target_detection'), '%Y-%m-%d_%H-%M-%S-%f')) < 30 }}' but no default was specified') while processing template 'Template("{{as_timestamp(now()) - as_timestamp(strptime(state_attr('image_processing.deepstack_object_ip_camera_north', 'last_target_detection'), '%Y-%m-%d_%H-%M-%S-%f')) < 30 }}")' for attribute '_attr_native_value' in entity 'sensor.north_target_detected'
That will eliminate the error but will give a potentially erroneous true result because now() minus 0 will always be greater than 30.
I think in some cases it may be better to accept the error and not allow the template to render than to give a false positive or negative result. Especially if the error is only ever generated at start up.
Thank you - I really appreciate your help with this. I’ve now discovered a further issue. The entity attribute last_target_detection is not generated until an image scan has been run and a target has been detected.
I need the automation to continue even though the value template is throwing an error. Is there a way to ignore value template errors when processing an automation?
See below. Note, i’m currently using a timer workaround instead of the value template. It works, but ideally I would like to use the value template as it would be more CPU efficient given there would be a 30s pause in sending further images to the AI engine once a target had been found. Without this, when movement detected by the camera, images would continue to be sent to the AI engine however notifications would be throttled via the timer. Considerable CPU time would be spent processing images which would never be used in a notification.
alias: >-
Camera North - (DeepStack:Processing+Notify)
description: >-
Trigger on motion detected by camera north.
Perform image processing service call to reset counter state. (counter state records number of targets found in previous image processed)
*Disabled* Only perform image processing if a target HAS NOT been found in the past 30s
If target found during counter reset process then stop automation (notify will
trigger when target detected)
If no target found then loop while motion is on and there is no target
detected until either target detected or motion is off.
If target detected then notify will trigger.
- platform: state
entity_id:
- binary_sensor.north_motion
to: 'on'
- platform: event
event_type: deepstack.object_detected
event_data:
condition: []
- choose:
- conditions:
- condition: trigger
- condition: template
value_template: >-
'last_target_detection'), '%Y-%m-%d_%H-%M-%S-%f')) > 30 }}
enabled: false
sequence:
- service: image_processing.scan
data: {}
entity_id: image_processing.deepstack_object_ip_camera_north
- if:
- condition: numeric_state
above: '0'
then:
- stop: ''
else:
- repeat:
while:
- condition: not
conditions:
- condition: state
entity_id: binary_sensor.north_motion
state: 'off'
above: '0'
sequence:
- delay:
hours: 0
minutes: 0
seconds: 2
milliseconds: 0
enabled: false
data: {}
- conditions:
- condition: state
entity_id: timer.camera_north_person_detection_timer
state: idle
enabled: true
sequence:
- service: notify.cergon
message: >-
Detected {{ trigger.event.data.name }} with confidence {{
trigger.event.data.confidence }}
image: /media/local/deepstack_object_ip_camera_north_latest.jpg
clickAction: /lovelace-mobile/security
group: Security
title: 'ALERT:'
- service: notify.mobile_app_wall_display
message: TTS
title: ALERT! {{ trigger.event.data.name }} detected at front of house.
- service: timer.start
duration: '00:00:30'
enabled: true
default: []
mode: parallel
