Value template with state attribute error
Can any body tell me what’s wrong with this code? Probably with a focus on the contents of the value_template.
    sensors:
      last_run_zone_1:
        friendly_name: "Last Run"
        value_template: '{{ (as_timestamp(state_attr('automation.activate_zone_1_timer','last_triggered'))) |   timestamp_custom("%A, %d %h %H:%M") }}'
Returns error
Error: INFO:homeassistant.util.package:Attempting install of colorlog==4.0.2
Testing configuration at /config
ERROR:homeassistant.util.yaml:while parsing a block mapping
  in "/config/configuration.yaml", line 338, column 9
expected <block end>, but found '<scalar>'
  in "/config/configuration.yaml", line 339, column 55
Failed config
  General Errors:
- Error loading /config/configuration.yaml: while parsing a block mapping
Successful config (partial)
But if I run the same value template in template checker then I get the following, which is as expected.
Tuesday, 26 Feb 18:30
Thanks for any help.
Check the quotes.
If you have double ones in the template you must wrap them in single ones.
Brilliant! Many thanks that resolved it.
