I’m attempting to display an integer value in a state-badge for my living room temperature (sensor.living_room_temperature), and from reading these forums I’ve gone about this as follows.
Inside configuration.yaml…
sensors: !include sensors.yaml
Inside sensors.yaml, created in the same folder as configuration.yaml…
sensors:
livingroomtemp:
value_template: "{{ states('sensor.living_toom_temperature') | int }}"
Inside my lovelace config…
- type: state-badge
entity: sensor.livingroomtemp
style:
top: 44%
left: 57%
color: 'rgba(0,0,0,0)'
But all this results in is an error on my floorplan stating entity sensor.livingroomtemp can’t be found.
At which step have I gone wrong here?
You need to remove the line sensor: from the top of your sensors.yaml
Also remove the s from the end of sensors: in configuration.yaml.
Then reload homeassistant.
Thank you for the prompt input!
I now have this…
$ cat configuration.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
sensor: !include sensors.yaml
$ cat sensors.yaml
sensors:
livingroomtemp:
And have restarted Home Assistant, but still get the same error.
I don’t think you need a sensor that converts the sensor to an int, did you try using sensor.living_room_temperature
directly in lovelace?
I also notice you have a typo in the sensor config you wrote toom
instead of room
Yes I did try it directly, but it reports to two decimal places.
And thank you for the toom spot! ![:joy: :joy:](https://community.home-assistant.io/images/emoji/twitter/joy.png?v=9)
Unfortunately after a restart it’s still showing the same error.
$ cat sensors.yaml
sensors:
livingroomtemp:
value_template: "{{ states('sensor.living_room_temperature') | int }}"
default_config:
# Text to speech
tts:
- type: state-badge
style:
top: 44%
left: 57%
Can you see the entity under Developer Tools -> States?
There’s nothing relevant in the logs, and no I can’t see sensor.livingroomtemp in Developer Tools -> States.
I think the penny has just dropped: I’m running Home Assistant in Docker and appear to have two sets of directories with configuration.yaml present…
/usr/share/hassio/homeassistant
/home/pi/homeassistant
…and I’d been editing the latter. Setting all this up in the former appears to work perfectly!
(Should I be deleting the latter to avoid any future confusion?)
This looks like you are running Home Assistant Supervised (add-ons,automatic updates, snapshots etc.),so the second path should not be relevant. I’d still do a backup of the directory first before removing it.
