Vanderbilt SPC Component fail after reboot
My SPC component always fails after reboot, is there something I can do to fix this without restarting a couple of more times and hope it will fix it self?
Log:
Setup failed for spc: Integration failed to initialize.
1:07 PM setup.py (ERROR)
Failed to load area/zone information from SPC.
1:07 PM components/spc/init.py (ERROR)
Setup of person is taking over 10 seconds.
1:07 PM main.py (WARNING)
Timeout getting SPC data from http://192.168.0.55:8088/spc/zone.
1:07 PM main.py (ERROR)
Setup of spc is taking over 10 seconds.
I have the same problem.
Have you solved?
I reboot untill it works again, but it feels little bit more stable in the newer versions of Hass.io
I have the last version of ha but not works…
Sometimes after reboot, but often fails.
I have the same problem, always after Supervisor reboot.
11 april 2021 23:46:00 – (ERROR) setup.py
11 april 2021 23:46:00 – (ERROR) spc
Timeout getting SPC data from http://192.168.149.5:8088/spc/area.
11 april 2021 23:46:00 – (ERROR) /usr/local/lib/python3.8/site-packages/pyspcwebgw/utils.py
80% of the times i need to power HA down and the up again.
If that dont work i need to power down the SPC gateway.
