I have 2 automations for getting a notification when my 2 Irobot’s there bin is full.
That is working fine.
But I want 1 automation for both of the Vacuum cleaners. But I want the friendly name of the Vacuum in the notification. So I know which one has a full bin.
This is my automation of one vacuum cleaner
alias: Notificatie Carlos opvangbak vol
description: Stuur een notificatie naar Yves & Bjorn om Carlos zijn zak leeg te maken.
- type: turned_on
platform: device
device_id: bd115620d58ace81db0ccaf876e8a38e
entity_id: binary_sensor.carlos_bin_full
domain: binary_sensor
condition: []
- service: notify.notify
message: Carlos zijn opvangbak is vol
title: Carlos
mode: single
In the Message and Title I want the name to be variable. I tried already several things but it’s not working. So how can I get the name of the Vacuum cleaner in the message as a variable?
Now there is only one trigger, but if variable is working the will be 2 triggers.
One for vacuum cleaner 1 and one for vacuum cleaner 2.
- platform: state
entity_id:
- binary_sensor.carlos_bin_full
- binary_sensor.yves_bin_full
- binary_sensor.bjorn_bin_full
to: 'on'
condition: []
message: "{{ trigger.to_state.name }} is vol"
title: "{{ trigger.to_state.name }}"
mode: single
Home Assistant only knows the binary_sensor’s data, not other data like what you called the vacuum.
If all of the binary_sensor’s are in this format:
binary_sensor.vacuumname_bin_full
then we can extract the “vacuumname” portion like this:
- platform: state
entity_id:
to: 'on'
condition: []
- variables:
name: "{{ trigger.to_state.object_id.split('_')[0] | title }}"
message: "{{ name }} is vol"
title: "{{ name }}"
mode: single
So if binary_sensor.bjorn_bin_full is responsible for triggering the State Trigger, the value of trigger.to_state.object_id will be bjorn_bin_full.
If we split it at every underscore character it will produce a list like this ['bjorn', 'bin', 'full'] but we only want the first item in the list so we reference it using [0] because lists are zero-indexed. The result is bjorn.
Finally, we capitalize the first letter using the title filter to get Bjorn.
To reduce my automations I want 3 automations in 1 variable automations.
There are 3 devices that I want to send a notification when they have ended there cyclys.
This is my automation:
description: >-
Stuur een melding naar Yves & Bjorn wanneer een toestel het ingestelde
programma heeft voltooid
mode: single
- platform: numeric_state
entity_id: sensor.stopcontact_vaatwasser_power_2
for:
hours: 0
minutes: 2
seconds: 0
below: 1
entity_id: sensor.stopcontact_wasmachine_power_2
for:
hours: 0
minutes: 2
seconds: 0
below: 1
entity_id: sensor.stopcontact_droogkast_power_2
for:
hours: 0
minutes: 2
seconds: 0
below: 1
variables:
name: "{{ trigger.to_numeric_state.object_id.split('_')[0] }}"
condition:
- condition: state
entity_id: input_boolean.{{ name }}
state: "on"
- service: input_boolean.turn_off
data: {}
- service: notify.yves
message: >-
De {{ name }} is klaar met het ingestelde programma, {{ name }} leeg
maken aub.
title: {{ name }}
- service: tts.google_translate_say
entity_id:
- media_player.living_2
- media_player.keuken_2
- media_player.badkamer_2
- media_player.slaapkamer_2
message: >-
De {{ name }} is klaar met het ingestelde programma, {{ name }} leeg maken aub.
enabled: false
But I cannot save the automation because of this error: Message malformed: Entity input_boolean.{{ name }} is neither a valid entity ID nor a valid UUID for dictionary value @ data[‘condition’][0][‘entity_id’]
So the variable for the condition rule it not recognized.
Any one that can help?
If anyone has the same issue. I have used other method. So this is my automation now.
1 automation to check 3 devices if they have started or ended their cyclys.
alias: Notificatie wanneer een toestel gestart of klaar is met programma
description: >-
Stuur een melding naar Yves & Bjorn dat een toestel gestart of klaar is met
het ingestelde programma.
- type: power
platform: device
device_id: 8bd03b38ad09d6ffaa53d0be1b47447a
domain: sensor
above: 25
for:
hours: 0
minutes: 0
seconds: 0
- type: power
platform: device
domain: sensor
below: 1
for:
hours: 0
minutes: 5
seconds: 0
- type: power
platform: device
device_id: 5d01809d129d66d4affd1b72ef550b3e
domain: sensor
above: 25
- type: power
platform: device
domain: sensor
below: 1
for:
hours: 0
minutes: 5
seconds: 0
- type: power
platform: device
device_id: be4ff233254e252000cbe35b39a42ab6
domain: sensor
above: 25
- type: power
platform: device
domain: sensor
for:
hours: 0
minutes: 5
seconds: 0
below: 1
condition: []
- choose:
- conditions:
- condition: trigger
- condition: state
entity_id: input_boolean.vaatwasser
state: "off"
sequence:
data: {}
message: Vaatwasser is gestart met het ingesteld programma
title: Vaatwasser
- conditions:
- condition: state
state: "on"
sequence:
data: {}
message: Vaatwasser is klaar en kan worden uitgeladen.
title: Vaatwasser
entity_id:
message: >-
De vaatwasser is klaar met het ingestelde programma en kan
worden uitgeladen.
- conditions:
- condition: state
entity_id: input_boolean.wasmachine
state: "off"
sequence:
data: {}
message: Wasmachine is gestart met het ingesteld programma
title: Wasmachine
- conditions:
- condition: state
state: "on"
sequence:
data: {}
message: Wasmachine is klaar en kan worden uitgeladen.
title: Wasmachine
entity_id:
message: >-
De wasmachine is klaar met het ingestelde programma en kan
worden uitgeladen.
- conditions:
- condition: state
entity_id: input_boolean.droogkast
state: "off"
sequence:
data: {}
message: Droogkast is gestart met het ingesteld programma
title: Droogkast
- conditions:
- condition: state
state: "on"
sequence:
data: {}
message: Droogkast is klaar en kan worden uitgeladen.
title: Droogkast
entity_id:
message: >-
De droogkast is klaar met het ingestelde programma en kan worden
uitgeladen.
mode: queued
For future reference, the trigger variable doesn’t have a to_numeric_state property. As a result, your template for name produces a null value which causes the error message wherever name is referenced.
In addition, it contains syntax errors like this one:
title: {{ name }}
The template lacks outer quotes. If a template is on the same line as the option, it must be quoted.
I am doing ping test of network devices and can successfully pass the name of the device that went offline with the “Device “{{ trigger.to_state.attributes.friendly_name }}” is offline”. I want to do another test every 30 minutes after failure to tell me which devices remain offline with a numeric value of 0 but I can’t see how to pass the friendly name in this test because none have had a state change. For it to pass the test, it has to already be at 0. How can I pass along the friendly name for the device that remains at 0 and has not had a state change?
