I know how to pass variables to scripts, but I would like to know how to make these variables available in subscripts also, just like an “export variable” would do in Unix…
test_script:
- service: notify.telegram_xxx
message: "Variable in main script is {{ my_variable }} "
- service: script.turn_on
entity_id: script.test_subscript
test_subscript:
sequence:
message: "Variable in subscript is {{ my_variable }} "
I receive in Telegram :
Variable in main script is SuperVar
Variable in subscript script is
I know I could call my subscript setting the variables again, but I have scripts calling scripts and it’d be cleaner to have the variables available for all subscripts instead of having to declare for every call of a script.
Indeed as I said in my post I know I can keep on setting variables and sub variables for each scripts calls, but it’ll get messy quickly.
If there is no other way that’s what I’ll do but it’d be cleaner to be hable to propagate a value.
The variable I want to pass is volume and media player entity for a custom alarm played on Google Homes.
I have scripts to prepare alarm, turn on, turn off, restore state, etc… And so for instance the volume and entity should be passed from the main script to all possible sub-scripts. I can set all variables in each script calls each time, but that’s a lot of overhead.
