Hi Forum!
I ran into a rather strange error where I’m completely out of my league - maybe somebody can help. I used to run a old installation of hass.io which is now completely outdate (over a year) and I decided to start fresh. (direct installation in docker etc.)
I used and would like to use again the great variables by @rogro82 (https://github.com/rogro82/hass-variables) This worked in the old installation. Now I try to rerun my old automation but i cant get it to work.
I have a rather simple counter which is increased each night (for a notification to change my water filter)
The following (test) section in my configuration.yaml works (turnes on the light) but does not increment the counter.
variable:
bfilter:
value: 42
#restore: true
attributes:
icon: mdi:filter
friendly_name: "Brittafilter Alter"
automation:
- alias: Test_auto
description: ''
- device_id: 94d39c5b36b862bf2d0995f1d6a3ce04
domain: deconz
platform: device
type: remote_button_short_press
subtype: turn_on
condition: []
- type: turn_on
device_id: 6ba48e9a23a7a8f779f835b17808228d
entity_id: light.tf_lab_status
domain: light
brightness_pct: 90
- service: variable.set_variable
variable: "bfilter"
value_template: '{{ (variable.state | int) + 1 }}'
mode: single
running the same stuff in the development tool works!
(it increments the variable)
Executing the automation yields the following execptions:
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 144, in async_prepare_call_from_config
service_data.update(template.render_complex(config[conf], variables))
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 91, in render_complex
return {
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 92, in <dictcomp>
render_complex(key, variables): render_complex(item, variables)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 96, in render_complex
return value.async_render(variables)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 353, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: UndefinedError: 'variable' is undefined
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 433, in async_trigger
await self.action_script.async_run(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1010, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 245, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 253, in _async_step
await getattr(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 432, in _async_call_service_step
domain, service, service_data = async_prepare_call_from_config(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 146, in async_prepare_call_from_config
raise HomeAssistantError(f"Error rendering data template: {ex}") from ex
homeassistant.exceptions.HomeAssistantError: Error rendering data template: UndefinedError: 'variable' is undefined
Anybody a idea what I’m doing wrong?
