Good morning!
Trying to put together a Notifier script that will handle all my notification needs. I’ve found that I’ve been embedding logic for notifications in different automations and it’s getting annoying. My intent is to have one subroutine-style script I can call from automations, with a set of options, that will handle my needs - notify me, my wife, when we’re home, or away, or away but only if we’ve just left, etc etc.
I’m running into a logical problem that I think has to do with variable scope. It appears variables don’t propagate back up out of loops? I’m using a set of Repeat/Choose blocks to iterate over our devices and the settings, evaluate, and if need be, notify.The loops set a “Actually Do It” flag, with the intent that I’d catch the flag at the end.
But that doesn’t seem to work. I initialize the variables up top as false and even when set true later on, it still gets evaluated as false later on. Is there no way to define a “Global” within a script?
Full code is below for anyone who wants to pick it apart. Thanks!
alias: Notifier New
sequence:
- variables:
SEND_CPG_PH: false
SEND_CPG_TB: false
SEND_ESG_PH: false
SEND_ESG_TB: false
SEND_TVS: false
- alias: Check Time Range
if:
- condition: template
value_template: >-
{% set current_date_string = now().strftime("%Y-%m-%d ") %}
{% set current_time = now().timestamp() %}
{% set start_timestamp =
strptime(current_date_string+input_start_time, '%Y-%m-%d
%H:%M:%S').timestamp() %}
{% set end_timestamp = strptime(current_date_string+input_end_time,
'%Y-%m-%d %H:%M:%S').timestamp() %}
{{ not (start_timestamp <= current_time <= end_timestamp) }}
alias: Test if time is within bounds.
then:
- stop: Not in allowed time range.
- alias: Check Targets for Reach
repeat:
sequence:
- variables:
TARGET: |
{{ repeat.item }}
TARGET_PRESENCE: |
{% if repeat.item == 'cpg_phone' %}
{{ states('device_tracker.starfury') }}
{% elif repeat.item == 'esg_phone' %}
{{ states('device_tracker.canary') }}
{% endif %}
SINCE_CHANGE: |
{{ as_timestamp(now()) - as_timestamp(states.device_tracker['starfury'].last_changed) }}
{{ as_timestamp(now()) - as_timestamp(states.device_tracker['canary'].last_changed) }}
{% endif %}
alias: Save the working target
- alias: Check Reach against each Target
repeat:
sequence:
- choose:
- conditions:
value_template: "{{ repeat.item == 'H' }}"
alias: Home
sequence:
- if:
- alias: Home Set
condition: template
value_template: "{{ TARGET_PRESENCE == 'home' }}"
then:
- choose:
- conditions:
value_template: "{{ TARGET == 'cpg_phone' }}"
sequence:
- variables:
SEND_CPG_PH: true
- conditions:
value_template: "{{ TARGET == 'esg_phone' }}"
sequence:
- variables:
SEND_ESG_PH: true
alias: Set correct Send variable
alias: Home
- conditions:
value_template: "{{ repeat.item == 'ARD' }}"
alias: Away, Recently Departed Set
sequence:
- alias: Check Occupancy, Away Time, and Set Variable
choose:
- conditions:
alias: Target is Chris
- condition: not
conditions:
- condition: state
entity_id: person.chris
state: home
alias: Chris Not Home
value_template: "{{ SINCE_CHANGE <= ( input_ard_time * 60 ) }}"
alias: Away within ARD time
sequence:
- variables:
SEND_CPG_PH: true
- conditions:
- alias: Target is Chris
condition: template
- alias: Chris Not Home
condition: not
conditions:
- condition: state
entity_id: person.emily
state: home
sequence:
- variables:
SEND_ESG_PH: true
alias: Target is Emily
- conditions:
value_template: "{{ repeat.item == 'ANH' }}"
sequence:
- alias: Check Occupancy and Set Variable
choose:
- conditions:
- condition: numeric_state
entity_id: zone.home
below: 1
alias: Home is Vacant
sequence:
- variables:
SEND_CPG_PH: true
- conditions:
- alias: Target is Emily
condition: template
below: 1
sequence:
- variables:
SEND_ESG_PH: true
alias: Away, if Nobody is Home
- conditions:
value_template: "{{ repeat.item == 'OOT' }}"
alias: Out of Town Set
sequence:
- alias: Check Proximity and Set Variable
choose:
- conditions:
entity_id: sensor.home_chris_distance
above: 528000
alias: Chris > 100mi
sequence:
- variables:
SEND_CPG_PH: true
- conditions:
condition: template
- alias: Emily > 100mi
entity_id: sensor.home_emily_distance
above: 528000
sequence:
- variables:
SEND_ESG_PH: true
alias: Out of Town
for_each: "{{ input_reach }}"
for_each: "{{ input_targets }}"
- alias: Send to Chris' Phone
if:
- alias: Send flag is True
condition: template
value_template: "{{ SEND_CPG_PH }}"
then:
- metadata: {}
message: "{{ input_message }}"
title: "{{ input_title }}"
action: notify.mobile_app_starfury
mode: parallel
icon: mdi:bullhorn
description: Standardized Notifier for all targets.
fields:
input_targets:
description: Target to notify
selector:
select:
multiple: true
mode: dropdown
options:
- label: Chris' Phone
value: cpg_phone
- label: Chris' Tablet
value: cpg_tablet
- label: Emily's Phone
value: esg_phone
- label: Emily's Tablet
value: esg_tablet
- label: TVs
value: tvs
required: true
input_reach:
description: Will this notification go to people at home, away or out of town
default:
- S
- H
- ANH
- ARD
selector:
select:
multiple: true
options:
- label: Out of Town (>100 mi)
value: OOT
- label: Away
value: A
- label: Away, Nobody Home
value: ANH
- label: Away, Recently Departed
value: ARD
- label: Home
value: H
input_title:
selector:
template: {}
description: Title to show in the notification (Mobile Only)
required: false
input_message:
selector:
template: {}
description: The message to send
required: true
input_notify_settings:
name: Settings for Notify
selector:
template: null
description: Additional to attach as part of the data to the notify.
required: false
input_start_time:
description: When notifications should start being allowed
default: "07:30:00"
selector:
time: null
required: true
input_end_time:
description: When notifications should stop being allowed
default: "23:00:00"
selector:
time: null
required: true
input_ard_time:
selector:
number:
min: 1
max: 10
step: 1
description: >-
When using 'Away, Recently Departed', how much time counts for 'Recent'.
(In Minutes)
default: 2
max: 100
