Variable value changes
i’m using
my question is everytime home assistant restarts, the value of the variable goes back to 'Unknown" This is my variable config:
Maindoor_lastupdate:
attributes:
icon: mdi:door-closed
restore: true
Depending on what version you are using, that component might not be compatible anymore.
I’m using HA v0.104.x any other variable component options?
I think he meant that maybe the custom integration isn’t compatible with HA anymore.
To answer your question, HA has several built-in “variables”: input_text, input_number, input_boolean, input_select and input_datetime. And they all save/restore across restarts.
