I’m trying to pass two variables from an automation to a script to play a sound.
The script works if I hardcode the values, it is only when I try to use the variables that I get errors. I feel like I’m missing something obvious, any suggestions?
My automation:
- id: test_play_sound
alias: Testing Playing a Sound
initial_state: 'off'
- platform: sun
event: sunset
offset: "00:15:00"
- service: script.play_sound
sound_file: 'http://10.5.1.90:8123/local/notification_chime.m4a'
speaker_location: 'media_player.kitchen_1'
This does not work, you cannot mix data_template and data. Simply remove the data: line, so that volume_level becomes part of the data_template: section. Like this:
That is good to know. I’m still getting a startup error though even with the change.
The error is:
Invalid config for [script]: [data_template:] is an invalid option for [script]. Check: script->script->play_sound->sequence->2->data_template:. (See /home/ha/.homeassistant/configuration.yaml, line 87). Please check the docs at https://home-assistant.io/components/script/`
I’m importing my scripts in my configuration.yaml file with:
script: !include_dir_merge_named scripts
Could this be the issue; I tried putting the script directly in the configuration.yaml file but I still received the same error?
Thank you!! I totally overlooked that typo; I am going to need to install a YAML lint plugin and start using an IDE - maybe develop a build sequence before deploying.
Also, I don’t know why, but my mind just kept focusing on the media_player.volume_set sequence when I saw “2” in the error - I just blanked and I didn’t realize that the error message was an array and I should of went to the third service.
I can’t tell you how long I stared at this code thinking everything looks fine. I guess using IDEs all day have made be lazy and not so sharp…
Thanks again for the help. Everything is working fine.
Also, as a side note to anyone who has this similar issue, I had to remove the quotes in the automation variables to get everything to work.
That single-quote-in-the-variable-thing had me stumped for 24 hours, until I stumbled on this! You should put it in big bold letters, saved my (second) day!
