I have several energy monitoring plugs that are used to monitor particular energy guzzling appliances (washing machines, dishwashers, kettles etc).
I have automations in place for the dishwasher for start and end of cycles, based on power through the plug.
The end automation calculates the cost of the cycle based on a dishwasher_start_energy variable, dishwasher_stop_energy variable and the electricy_tariff value from my meter.
It writes a row to a spreadsheet, using IFTTT, with the event “dishwasher_ended”, the start and stop values and the cost value.
It seems to me that there should be a way of using variables so that all plugs could use the same automation (add every one to trigger) but change the actions to reflect the plug that triggered and thus read, say, a washingmachine_start/stop_energy value for the calculation and send a “washingmachine_ended” event to IFTTT.
I guess this would involve calling a script but not sure how the automation could recognise in the action which plug triggered and how to send and use that info in a script.
Here is a practical example of automation using variables and entity which triggered the automation…
This should help you and is answering some of your questions:
- alias: record_change_date_time
initial_state: true
- platform: state
entity_id:
- climate.aquatemp_poolstage
- climate.airco_bureau
- climate.airco_chambre_ma
- climate.airco_grenier
- climate.airco_chambre_parents
- climate.airco_chambre_thomas
- climate.veranda_c
- sensor.status_alarm_courcelles
to:
variables:
entity: >-
{% set string=trigger.entity_id %}
{% set string=string.split('.') %}
{% set result="input_datetime."+string[0]+"_"+string[1]+"_changed" %}
{{ result }}
- choose:
- conditions:
- "{{trigger.from_state.state != 'unavailable'}}"
- "{{trigger.to_state.state != 'unavailable'}}"
sequence:
- service: input_datetime.set_datetime
entity_id: "{{ entity }}"
date: '{{ as_timestamp(now()) | timestamp_custom("%Y-%m-%d") }}'
time: '{{ as_timestamp(now()) | timestamp_custom("%H:%M:%S") }}'
- service: notify.message_ha
data_template:
message: >-
{{ now().strftime("%Y-%m-%d %H:%M:%S ") }}**** DC-055.1 Date modified for {{ entity }}: state changed from {{ trigger.from_state.state }} to {{ trigger.to_state.state }}
default:
data_template:
message: >-
{{ now().strftime("%Y-%m-%d %H:%M:%S ") }}**** DC-055.1 Date NOT modified for {{ entity }}: state changed from {{ trigger.from_state.state }} to {{ trigger.to_state.state }}
