Can variables refer to previous variables. i.e. does this work?
Can I reduce this:
#=== Update last run time for this zone
- service: input_text.set_value
data_template:
entity_id: >
input_text.irrigation_{{ zone }}_previous_duration_in_seconds
value: >
{% set original_duration = states('sensor.irrigation_' ~ cycle ~ '_' ~ zone ~ '_actual_duration_in_seconds') | float %}
{% set duration_remaining = state_attr('timer.irrigation_' ~ zone ~ '_timer', 'remaining') %}
{% set duration_remaining_hrs = duration_remaining.split(':')[0] | float %}
{% set duration_remaining_mins = duration_remaining.split(':')[1] | float %}
{% set duration_remaining_secs = duration_remaining.split(':')[2] | float %}
{% set duration_remaining_secs = duration_remaining_secs + (duration_remaining_mins * 60) + (duration_remaining_hrs * 3600) %}
{{ (original_duration - duration_remaining_secs) | string }}
To this1:
- variables:
original_duration: "states('sensor.irrigation_' ~ cycle ~ '_' ~ zone ~ '_actual_duration_in_seconds') | float"
duration_remaining: "state_attr('timer.irrigation_' ~ zone ~ '_timer', 'remaining')"
duration_remaining_hrs: "duration_remaining.split(':')[0] | float"
duration_remaining_mins: "duration_remaining.split(':')[1] | float"
duration_remaining_secs: "duration_remaining.split(':')[2] | float + (duration_remaining_mins * 60) + (duration_remaining_hrs * 3600)"
data_template:
entity_id: "input_text.irrigation_{{ zone }}_previous_duration_in_seconds"
value: "{{ (original_duration - duration_remaining_secs) | string }}"
1 This is a reduced example, the variables will be reused further down the script and I have a feeling that if the right people look at this then they will tell me there is a better way to have written those templates. But even if that is true, the general question still holds.
I did but I wasn’t sure if a templated variable could be referred to in a later variable within the same ‘block’. But I suppose there’d be no difference.
Also I just saw the discussion on anchors. If I read that right it seems that whole block of jinja where I set the variables could also just be an anchor if I can get the indentation right…?
Although using variables: is infinitely more readable IMO.
yep.I just tested that, a complete condition and action block in anchors, including the new variable with a template
how’s that for a Thursday evening.
entity_picture_template: >
{% set person = states.device_tracker.life360_marijn %}
<<: &location_picture
{% set zones = states.zone|map(attribute='name')|list %}
{% if person.attributes.country_code and person.attributes.country_code != 'nl' and
person.state not in zones and
person.state not in ['moving','driving'] %}
/local/flags/{{person.attributes.country_code}}.png
{% elif person.state in ['home','not_home'] %} {{person.attributes.entity_picture}}
{% else %}
/local/zones/{{person.state|lower|replace(' ','_')}}.png
{% endif %}
and
{% set person = states.device_tracker.life360_w %}
<<: *location_picture
Would be great to have the possibility to add a YAML file to configuration file that store all variables. So you can use them everywhere in automations, scrips… Something like a global_data.yaml
Otherwise you have in different locations variables and thats not easy to manage when you use a lot of them
Just use the custom hass-variables component by rogro82.
It works exactly as you want it to. You create the variables and put them wherever you want (all in one file or in packages) and you can use them wherever you want as often as you want.
but can we use it here, where the value_template is identical to the icon_template:
hour_icon:
friendly_name: Hour icon
value_template: >
{% set t = states('sensor.time') %}
{% set word = ['skipthis','one','two','three','four','five','six','seven',
'eight','nine','ten','eleven','twelve','one'] %}
{%- set hour = now().strftime('%-I')|int %}
{%- set minute = now().strftime('%-M')|int %}
{%- set index = hour if minute <= 30 else hour + 1 %}mdi:clock-time-{{word[index]}}
{{- '-outline' if states('sun.sun') != 'above_horizon' }}
icon_template: >
attribute_templates:
Hour: >
{{now().strftime('%-I')}}
Minutes: >
{{now().strftime('%-M')}}
Addition: >
{{0 if now().strftime('%-M')|int <= 30 else 1}}
this would be another example we could use the global variable in a template sensor…
