I am trying to create an automation around a IKEA TRADFRI Shortcut Button.
The basics are already working (i.e. reacting on the events the button sends).
I have found the following blueprint, which reacts also on virtual double clicks, for which the device does not send events itself.
Following this blueprint I want to adapt my automation, however I am having trouble with the variables section.
My automation currently looks as follows:
- alias: Light - Tradfri Shortcut Button
variables:
button_short: "1002"
button_long: "1001"
button_release: "1003"
platform: event
event_type: deconz_event
event_data:
id: tradfri_shortcut_button #ikea_e1812
mode: restart
max_exceeded: silent
condition:
# check that the button event is not empty
- condition: template
value_template: '{{ trigger.event.data.event not in ["","None"] }}'
- variables:
# adjusted debounce delay so that the resulting double press delay is exactly as specified by the user when running the action, taking also account of debouncing
# make sure it never goes below the minimum double press delay
adjusted_double_press_delay: "{{ [states('input_number.tradfri_double_press_delay') | int - states('input_number.tradfri_debounce_delay') | int, 100] | max }}"
trigger_action: "{{ trigger.event.data.event }}"
trigger_delta: "{{ (as_timestamp(now()) - as_timestamp((states('input_text.last_shortcut_button_event') | from_json).last_triggered if 'input_text.last_shortcut_button_event' is not none and (states('input_text.last_shortcut_button_event') | regex_match("^\{(\".*\": \".*\"(, )?)*\}$")) else "1970-01-01 00:00:00")) * 1000 }}""
# debouncing - when automation is triggered multiple times, the last automation run is the one which completes execution, due to mode restart
# therefore previous runs must wait for the debounce delay before executing any other action
# if the delay expires and the automation is still running it means it's the last run and execution can continue
- delay:
milliseconds: states('input_number.tradfri_debounce_delay') | int
- choose:
- conditions: '{{ trigger_action | string in button_short }}'
# Toggle Livingroom Rear
sequence:
- choose:
# if previous event was a short press
- conditions: "{{ trigger_action | string in states('input_text.last_shortcut_button_event') and trigger_delta | int <= states('input_number.tradfri_double_press_delay') | int }}"
sequence:
# store the double press event in the last controller event helper
- service: input_text.set_value
entity_id: input_text.last_shortcut_button_event
value: '{{ {"trigger_action":"double_press","last_triggered":now() | string} | to_json }}'
# run the double press action
- service: light.toggle
entity_id: light.livingroom_front
# previous event was not a short press
default:
# wait for the double press event to occur, within the provided delay
# if the second press is received, automation is restarted
- delay:
milliseconds: '{{ adjusted_double_press_delay }}'
# if delay expires, no second press was received, therefore run the short press action
# run the short press action
entity_id: light.livingroom_rear
- conditions: '{{ trigger_action | string in button_long }}'
# Toggle Livingroom Floor Lamp
sequence:
entity_id: light.livingroom_floor_lamp
- conditions: '{{ trigger_action | string in button_release }}'
sequence: []
But I am getting the following error checking my configuration:
Error loading /config/configuration.yaml: while parsing a block mapping
in "/config/automation/light.yaml", line 44, column 7
expected <block end>, but found '<scalar>'
Am I missinterpreting how the variable section is working? Is there a typo somewhere, that I am not seeing? I do have other automations using partialy similar variable trigger_action: '{{ trigger.event.data.click_type }}'
which does work correctly.
In the documentation I can only find descriptions about variables within scripts, but not within automations.
Any help is welcome. Thank you.
