I’ve been working on an automation to turn off a fan when the humidity falls below a certain level, and this is now working fine.
However, the automation uses a hardcoded value in the 'below: ’ field. What I’d like to do is have this configurable, and an input number helper seemed ideal. I can set (and change) the number to anything I want.
However, I’m not sure whats wrong when I try to use it.
This is an extract from my automation:-
condition:
- type: is_humidity
condition: device
device_id: 457ad6a2ee920963e324bab25c4242db
entity_id: sensor.lumi_lumi_weather_humidity_3
domain: sensor
below: {{ states('input_number.ensuite_humidity_threshold') | float }}
But I cannot save this as I get this error on screen:-
Message malformed: expected float for dictionary value @ data[‘below’]
If I use the dev tools, it seems to evaluate correctly:-
I’m sure its something simple, but I can’t seem to figure it out.
