I fire a tap_action like this:
tap_action:
action: call-service
service: script.virt_ar_speisekammer
service_data:
select: select.e2m_virt_ar_speisekammer_action
what: AO
which: cover.ar_speisekammer
with a shortened script like this to explain the misery (see line with the comment):
alias: virt_ar_speisekammer
sequence:
- service: select.select_option
option: "{{ what }}"
entity_id: "{{ select }}"
- if:
- condition: state
entity_id: cover.ar_speisekammer # <== wanted this to be {{ which }} aswell
state: opening
then:
- service: cover.stop_cover
data: {}
entity_id: "{{ which }}"
mode: single
icon: mdi:transfer-up
the whole lot is somewhat longer, means the misery happens a dozend times in the complete script. I nailed it done to … works like a charm as long as one doesn’t want to pass the {{which}} which holds a cover entity_id within the condition section. And I have no idea about why it works for example in the service target section as wanted.
Help appreciated, TIA
