Hello everybody! I hope you can help me with these doubts I have because before upgrading I want to be sure that everything will work fine.
To put them in context I am using a NAS DS718+ where inside a virtual machine I have installed the home assistant OS.
My doubts are the following:
USB Zigbee cc2531 recognizes it and works correctly?
I have read that USB Bluetooth is no longer compatible, does it work inside the virtual machine even if it does not work inside synology but it does in virtual machines?
I use Surveillance Station so I can use them with Alexa, do the Surveillance Station camera entities still show up so I can still use them inside Alexa or inside my panel?
Did you find something wrong with home assistant when upgrading to DSM 7.0?
I know it’s a bit long but I hope you can help me. Thank you very much!
(Sorry if my English is not perfect but I use the translator).
