Hi guys,
I need some help or advice.
After a power failure, I have various errors in my Home Assistant instance.
Setup:
Raspberry Pi 400 - Dietpi Image (using a SSD as hard disc)
Installed directly via Dietpi: Home Assistant (2024.3.3), Adguard, unbound.
Installed via Docker: Teslamate, Grafana, Teslamatetelegrambot.
After a power failure, everything continues to run without errors. Only Home Assistant suddenly throws errors. I have tried a new installation directly via Dietpi ( dietpi-software reinstall 157). Unfortunately, the errors remain.
Here is the extract from the full HA log.
2024-04-03 10:16:17.383 ERROR (SyncWorker_5) [homeassistant.util.package] Unable to install package webrtc-noise-gain==1.2.3: error: subprocess-exited-with-error
× Building wheel for webrtc-noise-gain (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [83 lines of output]
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-aarch64-cpython-312
creating build/lib.linux-aarch64-cpython-312/webrtc_noise_gain
copying webrtc_noise_gain/__init__.py -> build/lib.linux-aarch64-cpython-312/webrtc_noise_gain
running build_ext
gcc -pthread -fno-strict-overflow -Wsign-compare -DNDEBUG -g -O3 -Wall -fPIC -I/home/homeassistant/.pyenv/versions/3.12.1/include/python3.12 -c -std=c++17 flagcheck.cpp -o flagcheck.o -std=c++17
<built-in>: internal compiler error: Segmentation fault
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-10/README.Bugs> for instructions.
gcc -pthread -fno-strict-overflow -Wsign-compare -DNDEBUG -g -O3 -Wall -fPIC -I/home/homeassistant/.pyenv/versions/3.12.1/include/python3.12 -c -std=c++17 flagcheck.cpp -o flagcheck.o -std=c++14
gcc -pthread -fno-strict-overflow -Wsign-compare -DNDEBUG -g -O3 -Wall -fPIC -I/home/homeassistant/.pyenv/versions/3.12.1/include/python3.12 -c -std=c++17 flagcheck.cpp -o flagcheck.o -std=c++11
File "/mnt/dietpi_userdata/homeassistant/deps/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 353, in <module>
main()
File "/mnt/dietpi_userdata/homeassistant/deps/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 335, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "/mnt/dietpi_userdata/homeassistant/deps/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 251, in build_wheel
return _build_backend().build_wheel(wheel_directory, config_settings,
File "/tmp/pip-build-env-ovo6te0y/overlay/lib/python3.12/site-packages/setuptools/build_meta.py", line 410, in build_wheel
return self._build_with_temp_dir(
File "/tmp/pip-build-env-ovo6te0y/overlay/lib/python3.12/site-packages/setuptools/build_meta.py", line 395, in _build_with_temp_dir
self.run_setup()
File "/tmp/pip-build-env-ovo6te0y/overlay/lib/python3.12/site-packages/setuptools/build_meta.py", line 487, in run_setup
super().run_setup(setup_script=setup_script)
File "/tmp/pip-build-env-ovo6te0y/overlay/lib/python3.12/site-packages/setuptools/build_meta.py", line 311, in run_setup
exec(code, locals())
File "<string>", line 563, in <module>
File "/tmp/pip-build-env-ovo6te0y/overlay/lib/python3.12/site-packages/setuptools/__init__.py", line 104, in setup
return distutils.core.setup(**attrs)
File "/tmp/pip-build-env-ovo6te0y/overlay/lib/python3.12/site-packages/setuptools/_distutils/core.py", line 185, in setup
return run_commands(dist)
File "/tmp/pip-build-env-ovo6te0y/overlay/lib/python3.12/site-packages/setuptools/_distutils/core.py", line 201, in run_commands
dist.run_commands()
File "/tmp/pip-build-env-ovo6te0y/overlay/lib/python3.12/site-packages/setuptools/_distutils/dist.py", line 969, in run_commands
self.run_command(cmd)
File "/tmp/pip-build-env-ovo6te0y/overlay/lib/python3.12/site-packages/setuptools/dist.py", line 967, in run_command
super().run_command(command)
File "/tmp/pip-build-env-ovo6te0y/overlay/lib/python3.12/site-packages/setuptools/_distutils/dist.py", line 988, in run_command
cmd_obj.run()
File "/tmp/pip-build-env-ovo6te0y/normal/lib/python3.12/site-packages/wheel/bdist_wheel.py", line 368, in run
self.run_command("build")
File "/tmp/pip-build-env-ovo6te0y/overlay/lib/python3.12/site-packages/setuptools/_distutils/cmd.py", line 318, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/tmp/pip-build-env-ovo6te0y/overlay/lib/python3.12/site-packages/setuptools/_distutils/command/build.py", line 131, in run
self.run_command(cmd_name)
cmd_obj.run()
File "/tmp/pip-build-env-ovo6te0y/overlay/lib/python3.12/site-packages/setuptools/command/build_ext.py", line 91, in run
_build_ext.run(self)
File "/tmp/pip-build-env-ovo6te0y/overlay/lib/python3.12/site-packages/setuptools/_distutils/command/build_ext.py", line 345, in run
self.build_extensions()
File "<string>", line 511, in build_extensions
File "/tmp/pip-build-env-ovo6te0y/overlay/lib/python3.12/site-packages/pybind11/setup_helpers.py", line 285, in build_extensions
ext.cxx_std = auto_cpp_level(self.compiler)
File "/tmp/pip-build-env-ovo6te0y/overlay/lib/python3.12/site-packages/pybind11/setup_helpers.py", line 268, in auto_cpp_level
raise RuntimeError(msg)
RuntimeError: Unsupported compiler -- at least C++11 support is needed!
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for webrtc-noise-gain
ERROR: Could not build wheels for webrtc-noise-gain, which is required to install pyproject.toml-based projects
2024-04-03 10:16:44.039 ERROR (SyncWorker_5) [homeassistant.util.package] Unable to install package webrtc-noise-gain==1.2.3: error: subprocess-exited-with-error
│ exit code: 1
running bdist_wheel
running build
running build_py
creating build
running build_ext
main()
File "/tmp/pip-build-env-0dib6rmh/overlay/lib/python3.12/site-packages/setuptools/build_meta.py", line 410, in build_wheel
File "/tmp/pip-build-env-0dib6rmh/overlay/lib/python3.12/site-packages/setuptools/build_meta.py", line 395, in _build_with_temp_dir
self.run_setup()
File "/tmp/pip-build-env-0dib6rmh/overlay/lib/python3.12/site-packages/setuptools/build_meta.py", line 487, in run_setup
File "/tmp/pip-build-env-0dib6rmh/overlay/lib/python3.12/site-packages/setuptools/build_meta.py", line 311, in run_setup
File "/tmp/pip-build-env-0dib6rmh/overlay/lib/python3.12/site-packages/setuptools/__init__.py", line 104, in setup
File "/tmp/pip-build-env-0dib6rmh/overlay/lib/python3.12/site-packages/setuptools/_distutils/core.py", line 185, in setup
File "/tmp/pip-build-env-0dib6rmh/overlay/lib/python3.12/site-packages/setuptools/_distutils/core.py", line 201, in run_commands
dist.run_commands()
File "/tmp/pip-build-env-0dib6rmh/overlay/lib/python3.12/site-packages/setuptools/_distutils/dist.py", line 969, in run_commands
File "/tmp/pip-build-env-0dib6rmh/overlay/lib/python3.12/site-packages/setuptools/dist.py", line 967, in run_command
File "/tmp/pip-build-env-0dib6rmh/overlay/lib/python3.12/site-packages/setuptools/_distutils/dist.py", line 988, in run_command
cmd_obj.run()
File "/tmp/pip-build-env-0dib6rmh/normal/lib/python3.12/site-packages/wheel/bdist_wheel.py", line 368, in run
File "/tmp/pip-build-env-0dib6rmh/overlay/lib/python3.12/site-packages/setuptools/_distutils/cmd.py", line 318, in run_command
cmd_obj.run()
File "/tmp/pip-build-env-0dib6rmh/overlay/lib/python3.12/site-packages/setuptools/_distutils/command/build.py", line 131, in run
cmd_obj.run()
File "/tmp/pip-build-env-0dib6rmh/overlay/lib/python3.12/site-packages/setuptools/command/build_ext.py", line 91, in run
File "/tmp/pip-build-env-0dib6rmh/overlay/lib/python3.12/site-packages/setuptools/_distutils/command/build_ext.py", line 345, in run
File "/tmp/pip-build-env-0dib6rmh/overlay/lib/python3.12/site-packages/pybind11/setup_helpers.py", line 285, in build_extensions
File "/tmp/pip-build-env-0dib6rmh/overlay/lib/python3.12/site-packages/pybind11/setup_helpers.py", line 268, in auto_cpp_level
[end of output]
2024-04-03 10:17:11.574 ERROR (SyncWorker_5) [homeassistant.util.package] Unable to install package webrtc-noise-gain==1.2.3: error: subprocess-exited-with-error
│ exit code: 1
running bdist_wheel
running build
running build_py
creating build
running build_ext
main()
File "/tmp/pip-build-env-c9hm8tly/overlay/lib/python3.12/site-packages/setuptools/build_meta.py", line 410, in build_wheel
File "/tmp/pip-build-env-c9hm8tly/overlay/lib/python3.12/site-packages/setuptools/build_meta.py", line 395, in _build_with_temp_dir
self.run_setup()
File "/tmp/pip-build-env-c9hm8tly/overlay/lib/python3.12/site-packages/setuptools/build_meta.py", line 487, in run_setup
File "/tmp/pip-build-env-c9hm8tly/overlay/lib/python3.12/site-packages/setuptools/build_meta.py", line 311, in run_setup
File "/tmp/pip-build-env-c9hm8tly/overlay/lib/python3.12/site-packages/setuptools/__init__.py", line 104, in setup
File "/tmp/pip-build-env-c9hm8tly/overlay/lib/python3.12/site-packages/setuptools/_distutils/core.py", line 185, in setup
File "/tmp/pip-build-env-c9hm8tly/overlay/lib/python3.12/site-packages/setuptools/_distutils/core.py", line 201, in run_commands
dist.run_commands()
File "/tmp/pip-build-env-c9hm8tly/overlay/lib/python3.12/site-packages/setuptools/_distutils/dist.py", line 969, in run_commands
File "/tmp/pip-build-env-c9hm8tly/overlay/lib/python3.12/site-packages/setuptools/dist.py", line 967, in run_command
File "/tmp/pip-build-env-c9hm8tly/overlay/lib/python3.12/site-packages/setuptools/_distutils/dist.py", line 988, in run_command
cmd_obj.run()
File "/tmp/pip-build-env-c9hm8tly/normal/lib/python3.12/site-packages/wheel/bdist_wheel.py", line 368, in run
File "/tmp/pip-build-env-c9hm8tly/overlay/lib/python3.12/site-packages/setuptools/_distutils/cmd.py", line 318, in run_command
cmd_obj.run()
File "/tmp/pip-build-env-c9hm8tly/overlay/lib/python3.12/site-packages/setuptools/_distutils/command/build.py", line 131, in run
cmd_obj.run()
File "/tmp/pip-build-env-c9hm8tly/overlay/lib/python3.12/site-packages/setuptools/command/build_ext.py", line 91, in run
File "/tmp/pip-build-env-c9hm8tly/overlay/lib/python3.12/site-packages/setuptools/_distutils/command/build_ext.py", line 345, in run
File "/tmp/pip-build-env-c9hm8tly/overlay/lib/python3.12/site-packages/pybind11/setup_helpers.py", line 285, in build_extensions
File "/tmp/pip-build-env-c9hm8tly/overlay/lib/python3.12/site-packages/pybind11/setup_helpers.py", line 268, in auto_cpp_level
[end of output]
2024-04-03 10:17:11.592 ERROR (MainThread) [homeassistant.setup] Setup failed for 'cloud': Requirements for assist_pipeline not found: ['webrtc-noise-gain==1.2.3'].
2024-04-03 10:17:18.522 ERROR (MainThread) [haffmpeg.core] FFmpeg fails [Errno 2] No such file or directory: 'ffmpeg'
File "/mnt/dietpi_userdata/homeassistant/deps/lib/python3.12/site-packages/haffmpeg/core.py", line 137, in open
self._proc = await self._loop.run_in_executor(None, proc_func)
File "/home/homeassistant/.pyenv/versions/3.12.1/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/home/homeassistant/.pyenv/versions/3.12.1/lib/python3.12/subprocess.py", line 1026, in __init__
self._execute_child(args, executable, preexec_fn, close_fds,
File "/home/homeassistant/.pyenv/versions/3.12.1/lib/python3.12/subprocess.py", line 1950, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: 'ffmpeg'
2024-04-03 10:17:18.569 WARNING (MainThread) [haffmpeg.tools] Error starting FFmpeg.
2024-04-03 10:17:19.295 ERROR (MainThread) [homeassistant.setup] Setup failed for 'mobile_app': Requirements for assist_pipeline not found: ['webrtc-noise-gain==1.2.3'].
2024-04-03 10:17:20.775 ERROR (MainThread) [homeassistant.setup] Setup failed for 'assist_pipeline': Requirements for assist_pipeline not found: ['webrtc-noise-gain==1.2.3'].
2024-04-03 10:17:20.775 ERROR (MainThread) [homeassistant.setup] Setup failed for 'cast': Requirements for assist_pipeline not found: ['webrtc-noise-gain==1.2.3'].
2024-04-03 10:17:20.795 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'default_config'. Setup failed for dependencies: ['assist_pipeline', 'cloud', 'mobile_app']
2024-04-03 10:17:20.796 ERROR (MainThread) [homeassistant.setup] Setup failed for 'default_config': (DependencyError(...), 'Could not setup dependencies: assist_pipeline, cloud, mobile_app')
2024-04-03 10:17:22.888 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'hacs' accesses hass.components.frontend. This is deprecated and will stop working in Home Assistant 2024.9, it should be updated to import functions used from frontend directly at custom_components/hacs/frontend.py, line 68: hass.components.frontend.async_register_built_in_panel(, please create a bug report at https://github.com/hacs/integration/issues
2024-04-03 10:17:30.848 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/home/homeassistant/.pyenv/versions/3.12.1/lib/python3.12/site-packages/homeassistant/helpers/discovery_flow.py", line 104, in _async_start
await gather_with_limited_concurrency(FLOW_INIT_LIMIT, *init_coros)
File "/home/homeassistant/.pyenv/versions/3.12.1/lib/python3.12/site-packages/homeassistant/util/async_.py", line 218, in gather_with_limited_concurrency
return await gather(
File "/home/homeassistant/.pyenv/versions/3.12.1/lib/python3.12/site-packages/homeassistant/util/async_.py", line 216, in sem_task
return await task
File "/home/homeassistant/.pyenv/versions/3.12.1/lib/python3.12/site-packages/homeassistant/config_entries.py", line 1050, in async_init
flow, result = await self._async_init(flow_id, handler, context, data)
File "/home/homeassistant/.pyenv/versions/3.12.1/lib/python3.12/site-packages/homeassistant/config_entries.py", line 1070, in _async_init
flow = await self.async_create_flow(handler, context=context, data=data)
File "/home/homeassistant/.pyenv/versions/3.12.1/lib/python3.12/site-packages/homeassistant/config_entries.py", line 1205, in async_create_flow
handler = await _async_get_flow_handler(
File "/home/homeassistant/.pyenv/versions/3.12.1/lib/python3.12/site-packages/homeassistant/config_entries.py", line 2463, in _async_get_flow_handler
await _load_integration(hass, domain, hass_config)
File "/home/homeassistant/.pyenv/versions/3.12.1/lib/python3.12/site-packages/homeassistant/config_entries.py", line 2440, in _load_integration
await async_process_deps_reqs(hass, hass_config, integration)
File "/home/homeassistant/.pyenv/versions/3.12.1/lib/python3.12/site-packages/homeassistant/setup.py", line 529, in async_process_deps_reqs
await requirements.async_get_integration_with_requirements(
File "/home/homeassistant/.pyenv/versions/3.12.1/lib/python3.12/site-packages/homeassistant/requirements.py", line 52, in async_get_integration_with_requirements
return await manager.async_get_integration_with_requirements(domain)
File "/home/homeassistant/.pyenv/versions/3.12.1/lib/python3.12/site-packages/homeassistant/requirements.py", line 175, in async_get_integration_with_requirements
await self._async_process_integration(integration, done)
File "/home/homeassistant/.pyenv/versions/3.12.1/lib/python3.12/site-packages/homeassistant/requirements.py", line 250, in _async_process_integration
raise exceptions[0]
File "/home/homeassistant/.pyenv/versions/3.12.1/lib/python3.12/site-packages/homeassistant/requirements.py", line 239, in _async_process_integration
await self.async_get_integration_with_requirements(dep, done)
raise exceptions[0]
File "/home/homeassistant/.pyenv/versions/3.12.1/lib/python3.12/site-packages/homeassistant/requirements.py", line 192, in _async_process_integration
await self.async_process_requirements(
File "/home/homeassistant/.pyenv/versions/3.12.1/lib/python3.12/site-packages/homeassistant/requirements.py", line 274, in async_process_requirements
self._raise_for_failed_requirements(name, missing)
File "/home/homeassistant/.pyenv/versions/3.12.1/lib/python3.12/site-packages/homeassistant/requirements.py", line 302, in _raise_for_failed_requirements
raise RequirementsNotFound(integration, [req])
homeassistant.requirements.RequirementsNotFound: Requirements for assist_pipeline not found: ['webrtc-noise-gain==1.2.3'].
2024-04-03 10:17:31.688 ERROR (MainThread) [homeassistant.setup] Setup failed for 'bluetooth_adapters': Requirements for assist_pipeline not found: ['webrtc-noise-gain==1.2.3'].
2024-04-03 10:17:31.689 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'homekit_controller'. Setup failed for dependencies: ['bluetooth_adapters']
2024-04-03 10:17:31.690 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'homekit_controller'. Setup failed for dependencies: ['bluetooth_adapters']
2024-04-03 10:17:31.691 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'homekit_controller'. Setup failed for dependencies: ['bluetooth_adapters']
2024-04-03 10:17:32.739 ERROR (MainThread) [aiodhcpwatcher] Cannot watch for dhcp packets without a functional packet filter: libpcap is not available. Cannot compile filter !
2024-04-03 10:23:07.651 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'homekit_controller'. Setup failed for dependencies: ['bluetooth_adapters']
2024-04-03 10:23:19.671 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/home/homeassistant/.pyenv/versions/3.12.1/lib/python3.12/site-packages/homeassistant/setup.py", line 526, in async_process_deps_reqs
raise DependencyError(failed_deps)
homeassistant.exceptions.DependencyError: (DependencyError(...), 'Could not setup dependencies: bluetooth_adapters')
2024-04-03 10:25:02.626 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'homekit_controller'. Setup failed for dependencies: ['bluetooth_adapters']
2024-04-03 10:25:10.497 ERROR (Recorder) [homeassistant] Error doing job: Task exception was never retrieved
