Vehicle-Service-Manager
[Custom Component] Vehicle Service Manager - Track your car's maintenance and service intervals
Hey everyone,
I am excited to share a new custom integration I’ve been working on: Vehicle Service Manager.
If you are like me and want to keep track of your car's maintenance schedule (like oil changes, brake inspections, or cabin filters) directly inside Home Assistant without manufactor apps, this integration is for you. It calculates service intervals based on both driven mileage and time elapsed.
Key Features
  • Dual Tracking: Monitors service intervals by kilometers/miles and days simultaneously.
  • Service Templates: Pre-defined templates for common maintenance tasks.
  • Flexible Inputs: Uses your existing odometer sensor from your vehicle's connected integration.
  • Automations Ready: Easily trigger notifications when a service task is due soon or overdue.
  • Dashboard Friendly: Generates clean entities for easy display in Lovelace cards.
How it Works
The integration creates a dedicated hub for your vehicle. You link your car's current odometer sensor to it or just type in the actual, and then define your maintenance intervals (e.g., "Oil Change" every 15,000 km or 365 days). Home Assistant will then track the remaining distance and time until the next service.
--> You need the GitHub - toxictody1337/vehicle-service-card: lovelace cards for Vehicle-Service-Manager integration · GitHub to add services and tyres
Installation
Currently, you can install it manually or add it as a custom repository in HACS:
  1. Open HACS > Integrations.
  2. Click the three dots in the top right and select Custom repositories.
  3. Paste the repository URL: https://github.com
  4. Select Integration as the category and click Add.
  5. Restart Home Assistant and add the integration via the standard UI Devices & Services page.
Screenshots / Configuration
Feedback & Contributions
This is an early release, so please let me know if you run into any bugs or have feature requests. Feel free to open an issue or a pull request on GitHub!
**GitHub Repository: GitHub - toxictody1337/vehicle-service-manager: Vehicle Service Manager for Home Assistant · GitHub
Hope you find it useful!
Hi, your integration looks awesome! sadly I don't speak german :confused: . Are you planning to implement the english translation? I noticed the file exists but it contains the same german translation.
Is this being actively worked? I love the idea and want to implement this as well but I will need this to be in english.
