@nyri81 - I just did this recently. Do the following:
In Apple Home app, remove the Gateway from the HomeKit home (Home Settings, Home Hubs & Bridges)
On the gateway device, hold the gear button on the back until the light blinks red, then release the button and press it one more time to confirm. This will reset the wifi settings on the gateway (but not the device pairings)
Go the the Velux Active App and choose Settings > Gateway > Setup Wifi and follow the steps
Once Wifi is setup, go to Home Assistant > Settings > Devices and you should see a HomeKit Controller discovery option for the Velux Gateway. Configure it and you should be good to go!
If you want to add them back into Apple Home as well, you can use the HomeKit Bridge integration in Home Assistant for that.
KLF 200 is an interface receiving signals from other-than-velux-products in order to control velux products (e.g. velux shutters close when your security system sends an alert), it kinda translates the language of communication used by different systems
KIG 300 is a hub/gateway used for full wireless control (e.g. close remote controllable blinds over wifi)
KIX 300 is a set consisting of 1pc hub and 2pcs remote controls
This is how I integrated it last time, working on a new HA instance now and for the life of me I cannot get it to work. Difference is I was on HAOS now on Container, wondering if it could be a port issueā¦
Thanks for the pointers!! Everything worked well until I tried (am still trying tbh) to add the gateway to HA via HomeKit integrationā¦
HA gets stuck at āPlease wait, starting configuration wizard for the integrationā and nothing happens! If I configure HomeKit natively, I can add the bridge and import accessories natively, however they donāt perform well under HomeKit and are unresponsive whilst they are spot on onto their VELUX native appā¦
Iām a bit lost as Iād like to control, integrate and automate those VELUX devices (28) with HA.
Hello everyone, Iām a bit lost. Iām trying to integrate the KIG 300 (app control) gateway into HA.
How did I start? I did configure the gateway and the first shade (SSL solar shade) via the velux app and it worked.
Then I did reset the gateway, configured wifi via the velux app and added the gateway in HA via homekit integration.
I did detect the shade, but it has no connection.
Now two questions:
How can I fix the device with the broken connection?
How can I add another two shades (SML with KUX 110)? Do I need to reset the gateway, connect it to the velux app, add both shades there and then reset the gateway again, connect it to wifi and re-add it to HA?
I canāt remember all the troubles I went through in detail, but I ended up setting up the KIG 300 as Homekit device (including all shades) and then from HA I created a switch (āshades target stateā) which I exposed to Apple Home. When my HA sensors (temperature, luminosity, weather) show that the shades should close, I set the target state to on. In Apple Home I then have a simple automation that will control all shades depending on the state of this switch.
In case someone has a waterproof description on how to natively integrate the KIG 300 into HA, Iām interested too. I donāt have room for errors as the reset button on my shades is inside the motor, so I cannot access that without climbing on the roof (which I wonāt do).
Is anyone able to help me. Iāve followed the instructions (reset the velux active) and home assistant is discovering it correctly in devices and giving me the option to āconfigureā. When I select that, it gets stuck on āPlease wait, starting configuration wizard for the integrationā. Iāve tried restarting the velux hub, anything else I can try. I havenāt re-added it to homekit on my iphone, as once its part of apple management, I understand I canāt remove it. I did have it added before and removed it, but it didnāt show up for pairing. Any pointers much appreciated.
Unfortunately the KIG300 is cloud based, at least when using the iOS Velux app. Iām unsure if it will work as a Homekit device locally, if it requires the internet before sending the commands to the shades with its radio.
I have successfully added my Velux KIG300 to Home Assistant.
All windows and blinds appear in Home (iOS Homekit).
However, I cannot move these devices to another room in the Home app.
Is there a trick? Or does this have to be configured somehow in Home Assistant.
Iām not very comfortable with Home Assistant yet.
Maybe someone can give me a tip.
Short addendum:
I barely wait 30 minutes and then suddenly it works.
I have now been able to move the windows and blinds into the correct rooms.
Apparently the error was in the Home app on the iPhone, but it now worked on the Mac.
