Is there any way that the velux component can support tilt functionality for controlling vertical blind slats powered by a somfy io motor?
It is based on PyVLX but the following are not supported:
cover.open_cover_tilt
cover.close_cover_tilt
cover.stop_cover_tilt
Does the Velux KLF 200 API support tilt ?
Will be included in one of the next releases. For the time beeing my HACS custom component supports tilt functionality: https://github.com/pawlizio/my_velux
Thank you!
Do you know the ETA for it to be built into the official component?
In the meantime will try your custom component!
KLF200 is a bit pricey $$$.
does anybody know if it’s an alternative way to remote control your Velux.
does anybody reverse engineering the signal, could we control it with RM3 or equivalent remote controler ??? frequency ?
In May 2021, the new VELUX APP (KIG 300 EU) was launched. to be investigated
Hi , are there some updates about the new app control.
