Velux Integration: KLF200 or KIX300?
Hi All
I have recently installed a few Velux electrical windows & shutters and I want to integrate Velux into HA. What I read is that I can use KLF200 or KIX300 (via HomeKit).
What is your recommendation? What gives best options? What I figured out so-far (but I might be wrong)
KLF200
  • no active Velux development anymore?
  • gateway is a bit cheaper
  • no dependency on remote (cloud) provider
KIX300
  • active Velux development
  • I cannot not purchase a stand alone gateway, only starter kit ?
  • dependency on remote provider?
Any thoughts are appreciated :slight_smile:
From another Forum user, the KLF is discontinued:
Also, from my experience (as well as many others), the KLF is too prone to communications failures w. HA.
As for the KIX300, I have not used one, so I really can’t say if it is better or not.
In case you are interested, check out my comment in this other thread:
Hi, just popping in to ask how did it go with KIX300? Did you manage to integrate it into homeassitant?
I’ve just integrated the KIG300 gateway via Homekit - followed the steps documented in the other thread. I appear to get control and basic reporting of position on the motorised window and blind I’ve added, which is good enough for me. I don’t believe there’s any exposed info on the rain sensor
hello
I have just acquired the KIG 300 and I would like to integrate it into home assistant to be able to control my electric velux and an electric blind (flat roof). Can you explain step by step this integration into HA thank you
I just followed the instructions here - I did have to reset the gateway once and start again but I think that’s more down to my network being patchy at the time
