Just update to 2023.4.4 - after that the velux integration doesnt connect
anymore. did a reboot of HA and velux KLF200, but still doesnt work.
the KLF200 is online and the covers can be identified.
2023-04-16 17:18:59.176 WARNING (MainThread) [homeassistant.setup] Setup of velux is taking over 10 seconds.
2023-04-16 17:19:42.344 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: velux
2023-04-16 17:19:49.216 ERROR (MainThread) [homeassistant.setup] Error during setup of component velux
File "/usr/src/homeassistant/homeassistant/setup.py", line 256, in _async_setup_component
result = await task
File "/usr/src/homeassistant/homeassistant/components/velux/__init__.py", line 39, in async_setup
await hass.data[DATA_VELUX].async_start()
File "/usr/src/homeassistant/homeassistant/components/velux/__init__.py", line 84, in async_start
await self.pyvlx.load_scenes()
File "/usr/local/lib/python3.10/site-packages/pyvlx/pyvlx.py", line 82, in load_scenes
await self.scenes.load()
File "/usr/local/lib/python3.10/site-packages/pyvlx/scenes.py", line 51, in load
await get_scene_list.do_api_call()
File "/usr/local/lib/python3.10/site-packages/pyvlx/api/api_event.py", line 21, in do_api_call
await self.send_frame()
File "/usr/local/lib/python3.10/site-packages/pyvlx/api/api_event.py", line 33, in send_frame
await self.pyvlx.send_frame(self.request_frame())
File "/usr/local/lib/python3.10/site-packages/pyvlx/pyvlx.py", line 66, in send_frame
await self.connect()
File "/usr/local/lib/python3.10/site-packages/pyvlx/pyvlx.py", line 43, in connect
await self.connection.connect()
File "/usr/local/lib/python3.10/site-packages/pyvlx/connection.py", line 86, in connect
self.transport, _ = await self.loop.create_connection(
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1103, in create_connection
transport, protocol = await self._create_connection_transport(
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1133, in _create_connection_transport
await waiter
ConnectionAbortedError: SSL handshake is taking longer than 60.0 seconds: aborting the connection
Does your router show the klf200 connected to wi-fi with the same IP address as before i.e. as defined in configuration.yaml? The error suggests HA cant reach it.
From what I can tell, the Errno 113 has to do with connectivity to the address and port. Did I understand correctly from the other thread that you reverted back to 2024,4 and this made it work again? If yes, then this one may be a bit hard to debug. My only suggestions is that with 2024.5, is to ssh into HA and see if you can ping 192.168.1.32. If you can ping it, then… well …I don’t know. It could still be the same old problem with the KLF200 not accepting any more connections, but hard to tell.
For me, I use an automation on an HA Shutdown event to reboot the KLF200 using its service call. Been using it a long time. Every since I started using it, it has reduced the need to power-cycle the KLF to maybe a couple of times a year.
Do you also have blinds or only Veluw windows?
I have an issue that my blinds are not reporting the state correctly anymore, that are open , but HA is telling me they are closed… I use the custom one
