im about to purchase the above hardware but im a bit confused. It has wifi but it seems this only creates a own network and can not be part of the existing network? I want to use this integration Velux - Home Assistant but how does it work without access to the “normal” network?
Thx for your reply. Which firmware version do you use? I heard that the ethernet port dont work with newer versions? It seems to be only a serviceport but no ethernet port for LAN
I use firmware 2.0.0.71, which is the latest version. This version has been released in 2018, so Velux doesn’t provide any more updates for it. That version works for me with ethernet.
Either one should work. In case you didn’t know, this is a classic problem that the KLF200 only allows a couple of TCP/IP connections, and it easily runs out and that is why HA can’t connect to it. The best solution is to power down, then power up the KLF200, then restart HA. It doesn’t always work, sometimes it may take several attempts before it works again.
I know the problem, but up to version 2024.1.6 everything works perfectly with the velux.reboot_gateway automation. After the update and several poweroff/on and reboots I was no longer able to get it to work.
After the downgrade to version 2024.1.6 everything works perfectly.
I’ll do some more tests…
