VELUX KLF 200 pairing with Somfy IO motors and remotes
I’ve 10 Somfy Shutters with Somfy Oximo io Motor and using the Smoove Origin io switch for each separate shutter.
Unfortunately it not sufficient for pairing! I had to use the tahoma box and export the key to the Velux KFL-200
The Network Connection of the KFL 200 cost a lot of nerves as it wasnt stable at all connecting it directly to a Fritz Box Router. As i also had a Netgears unmanage switch, the connection is stable and sync with 1Gbit instead of 10Mbit ( fritz ) .
Pairing was easy, either straight after exporting the key run the discover and it will sync with the tahoma box detecting all devices at once, or use the ‘prog’ key on one of the hand switches.
