Hi there, unfortunately I have had a problem with the velux KLF200 since the update to 2022.3. I have already reset the KLF and set everything up again. A restart doesn’t help either. I know that “SSL handshake is taking longer than 60.0 seconds: aborting the connection” is a known KLF bug. Unfortunately, all the solutions in the forum have not changed anything. does anyone have the same problem or can help me?
Logger: homeassistant.setup
Source: components/velux/__init__.py:84
First occurred: 09:51:14 (1 occurrences)
Last logged: 09:51:14
Error during setup of component velux
File "/usr/src/homeassistant/homeassistant/setup.py", line 235, in _async_setup_component
result = await task
File "/usr/src/homeassistant/homeassistant/components/velux/__init__.py", line 39, in async_setup
await hass.data[DATA_VELUX].async_start()
File "/usr/src/homeassistant/homeassistant/components/velux/__init__.py", line 84, in async_start
await self.pyvlx.load_scenes()
File "/usr/local/lib/python3.9/site-packages/pyvlx/pyvlx.py", line 80, in load_scenes
await self.scenes.load()
File "/usr/local/lib/python3.9/site-packages/pyvlx/scenes.py", line 51, in load
await get_scene_list.do_api_call()
File "/usr/local/lib/python3.9/site-packages/pyvlx/api/api_event.py", line 21, in do_api_call
await self.send_frame()
File "/usr/local/lib/python3.9/site-packages/pyvlx/api/api_event.py", line 33, in send_frame
await self.pyvlx.send_frame(self.request_frame())
File "/usr/local/lib/python3.9/site-packages/pyvlx/pyvlx.py", line 66, in send_frame
await self.connect()
File "/usr/local/lib/python3.9/site-packages/pyvlx/pyvlx.py", line 43, in connect
await self.connection.connect()
File "/usr/local/lib/python3.9/site-packages/pyvlx/connection.py", line 87, in connect
self.transport, _ = await self.loop.create_connection(
File "/usr/local/lib/python3.9/asyncio/base_events.py", line 1081, in create_connection
transport, protocol = await self._create_connection_transport(
File "/usr/local/lib/python3.9/asyncio/base_events.py", line 1111, in _create_connection_transport
await waiter
ConnectionAbortedError: SSL handshake is taking longer than 60.0 seconds: aborting the connection
