Velux Shutter and Window Automation KIG300
Hi guys,
I want to controll my Velux Cover and window with KIG 300. The Connection KIG 300 to HA works.
The automation should look as follows:
  1. press the Shelly Blu switch
  2. roller shutter moves to the upperend position 3. window opens for 10 minutes
  3. window closes
If the roller shutter is already in the upper end position, the window does not open. The sequence stops.
What is the error in my script?
Thank you very much!
